Old 08-11-2017, 11:54 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default 1782 Bearings
Has anyone found a reliable source for the 5/8" ball bearing that are used in the rear driveshaft joint?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-12-2017, 02:30 AM
Dirty Steve's Avatar
http://www.vxb.com/mobile/Product.as...ctCode=Kit8598
I found these to be considerably cheaper than Cub's prices. I put them in a 2182 last year. Drive shaft is smooooth.
Old 08-12-2017, 06:16 AM
Yep that's the deal.
Old 08-12-2017, 04:19 PM
EarlJ's Avatar
Awesome price and with 10 in the package you have enough to do them again when they fail...thanks for the info..
Old 08-12-2017, 06:34 PM
gdheck's Avatar
gdheck gdheck is offline
Try McMaster-Carr #9528K26 hard wear resistant E52100 alloy steel balls $7.72 for 25 of them. Almost $.19 a piece cheaper. You may not want that many though. They are the same as the brake expander balls in some of my Oliver tractors, so I wanted the larger package.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 08-12-2017, 07:11 PM
Odd..... I've lost more of those than I've seen that were too wore out to reuse.
Old 08-12-2017, 10:27 PM
gdheck's Avatar
The drive coupler balls or the ones out of a brake expander? I ended up with several expender balls that were all rusty and pitted that I replaced so the whole assembly would work smooth again. I replaced the ones in the drive coupler on my 1782 because they had never been greased and I had a bag of new ones. I should replace the coupler too one of these days. It's fairly sloppy.
Earl,
Don't forget to put a new o-ring and new boot, if needed, on each coupler. I put a small zip tie around the small end of the boot, so grease doesn't just push out between the boot and shaft. I pump grease in until I feel the boot start expanding.
Old 08-13-2017, 06:51 AM
Even better. Thanks for the link and the heads up!
Old 08-13-2017, 11:46 PM
EarlJ's Avatar
This tractors are slap wore out. I'm not sure they've been greased since leaving the factory. The p.o. said he's confident its over 10k..but still running strong.. Gotta love a bota diesel..
