Old 08-06-2017, 04:28 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default Any hay wagons out there?
Last year we had a hayride at the farm. We used just a two wheel trail which worked OK. I have two axles that I want to use for a wagon. Looking for any insight on building a wagon with these axles. Pictures note posting. I'll try edit. Still not connecting.
Old 08-06-2017, 06:20 PM
You want to build a four wheel wagon for your Cub? Or a regular sized one?
You can buy a pretty nice frame for a 4 wheel wagon through Northern Tool. Frame is extendable from 49" to 78". $284, and to my zip code shipping is about $75, so not a bad deal. You still have to build the bed.
http://www.northerntool.com/shop/too...ct_47661_47661
If nothing else, use the pics as a pattern to build your own. You don't need axles, as you can see, the whole running gear is fabricated.
Old 08-06-2017, 08:30 PM
john hall's Avatar
Full size wagon running gears should be fairly cheap as opposed to building one from scratch, or are you talking a small one like JMech was describing? Even then I might would just buy one. I have trouble enough backing a full sized wagon with a farm tractor with individual brakes and power steering, ain't no way I would want to try it with a Cadet.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-06-2017, 08:46 PM
Last year we used a 6' x 10' trailer behind the Kubota. Wife says we need a bigger wagon. Still can't get a photo to attach. Tried a e-mail saved photo. Comes up a connection problem.
Old 08-06-2017, 10:04 PM
If you want a regular sized hay wagon, they're a dime a dozen.... really.
Old 08-06-2017, 10:37 PM
My 3 year old grandson wanted to go for a hay ride,,,
He even loaded the grass clippings,,,
Kind of a DIY hay ride,,,
Did I use enough tractor??
Old 08-06-2017, 11:07 PM
A WEEEEE bit of overkill.
Old 08-07-2017, 12:12 AM
Terry C's Avatar
Terry C Terry C is offline
A weeee bit of underkill
Had to move it cause I was tired of mowing around it.
Pretty sure that wagon weighs twice what dad's B weighs empty.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
