Old 07-25-2017, 08:36 PM
Chucks ss Chucks ss is offline
Default 123 w/ 48 inch mower deck
My question is the lift frame assembly or quick release frame. . I appologize. For the wrong terminology. Basically i have it attached and the mower deck as well. On the 123 model .I have checked many videos and pics. Of every piece and they are correct. But the belt i got which 2 seperate dealers. Said are the correct belt. Well its way too loose. I have adjusted. The tensioner pulley to the max still no luck. Im. Not so computer savey, so getting pics here. Is not happening yet. So can anyone tell me by. The serial number on the back. Of the mower. To confirm the year. And. The number on the mower deck ? And does anyone have pics. Of the right quick attachment frame.? If have see some with. A triangle type attachement. To the front on Either side and others. With. A flat strap with a slot sorry for the rambling. But i want to get this figured out. Ps the belt part number i was goven was IH-473 462-R. ITS 3/8 X 81 INCHES
Old 07-25-2017, 10:49 PM
Gompers Gompers is offline
Are you sure it's a 48" deck?
There are different belts for the 42" and 48".
On my 125, which should be the same as your 123, with a 48" deck, the part number is 489397R3, which is 3/8 x 75" I believe.
I think all the 48's basically mount the same, with two pins on the back, and the two lift supports in the front that slide into the lift frame arms.
Old 07-25-2017, 10:58 PM
I guess im not sure if it is a 48 inch or not. I have allot to learn. About these 2 toys i have. Can u tell me how to tell
Old 07-25-2017, 11:00 PM
I was also giving this part number. For a belt but cant find anything on it IH-599 71C1
Old 07-25-2017, 11:02 PM
And yes thats how mine mount as well.
Old 07-25-2017, 11:37 PM
If you can post a pic, it's easy to tell.
The easy tell is that the outside blades on the 42" are quite a bit smaller than the main blade, whereas on the 48" they are closer to the same size.
Also, the 48" deck has a guide bar on the left side that wraps all the way around, whereas the 42" doesn't loop around the back. These get beat up and worn out a lot, though.
Also the 48" is quite a bit wider (obviously).
Anyway, the Belt Chart (which can be found in the technical library section) should tell you all you need to know.
That guide says 489397R3, which matches what I've got.
Old 07-25-2017, 11:39 PM
Is the tag on the deck? If not, turn the blades, the two outside one's so that they are pointing to the outside of the deck, (side to side) and measure across. Then you will know the cutting width...
Old 07-25-2017, 11:41 PM
Another thing is that on the 38 and 42, I believe the gauge wheel bracket bolts onto the back of the deck, where on the 48" they attach to a bracket that's welded to the back and top of the deck.
Old 07-26-2017, 01:00 AM
Its def a 48 inch deck. All 3 blades. The same size and has ring on outside that wraps around that helps. Thanks.
Old 07-26-2017, 01:32 AM
I don't think so...
Center blade 759-3851
Outside blades 759-3852
