Old 07-09-2017, 06:27 PM
familytime familytime is offline
Default 2182 ignition coil
Engine runs great but begins to have a miss after 5 to 10 minutes of work. I found a post in a kubota forum where someone had the same issue on a wg600, after several years, he replaced his ignition coil and it solved his issue. Can I use any ignition coil, like an msd from my local parts store or do I have to get the kubota one?
Old 07-09-2017, 07:52 PM
If it were me, I would use the proper Ignition Coil(s).
Old 07-09-2017, 11:21 PM
I was mainly curious if anyone had used a different coil.
Old 07-10-2017, 12:10 AM
Terry C's Avatar
Terry C Terry C is offline
I haven't and I wouldn't.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-10-2017, 06:48 AM
Dirty Steve's Avatar
If you are speaking about the distributor, them puppies are expensive. You can find whole engines in the $4-500 range.
https://buffalo.craigslist.org/grd/6180332468.html
Think fuel issues first. Remove fuel tank- clean thoroughly, remove tank valves-clean/replace, put new rubber tank bungs back in with the valves, replace every inch of fuel line with new fuel and clamps, and new fuel filter. Then onto checking the fuel pump and carburetor. Also, the power supply to the fuel shut off valve on carburetor can be notorius for inopportune shut downs. The 2182 in my link below did the same shut down trick. After fuel system maintenance and complete rewire it runs great.
Old 08-01-2017, 11:28 PM
Jibber's Avatar
Jibber Jibber is offline
I bought a $20 12v ignition coil from Advance Auto and has worked perfect. Will it last as long as a Denso or Bosch? Who knows, but with a Lifetime Warranty I will take my chances rather than spending $110.
Old 08-07-2017, 03:24 PM
Jibber's Avatar
Here is an update that may be helpful to others who might experience a miss in their WG-600. I had a similar issue with the engine missing after working under load for a bit.
I replaced the ignition coil with this one from Advance Auto:
https://shop.advanceautoparts.com/p/...9-P#fragment-1
It helped with the mis some but it was still there. So I then considered that vapor lock might be occurring. So, I wrapped the fuel line with foil from the fuel pump to the carb and from the fuel pump back to the fuel filter. Bingo! No mis whatsoever.
Old 08-07-2017, 04:02 PM
From Cub website.
KB-15661-68902
COIL-IGNITION
Price $182.44
Jibber, your option sounds a whole feces load better!!
Old 08-07-2017, 04:33 PM
Jibber's Avatar
Originally Posted by Dirty Steve View Post
From Cub website.
KB-15661-68902
COIL-IGNITION
Price $182.44
Yeah, tell me about it! And I had a coupon so it was only $19.99.
Old 08-07-2017, 09:18 PM
From Cub website.
KB-15661-68902
COIL-IGNITION
Price $182.44
$105 https://www.m-and-d.com/KUB-15661-68900.html
