Old 06-06-2017, 04:55 PM
zcub22 zcub22 is offline
Default 149 Points and Timing
Hi All. I'm working on my neighbors 149 and the wide frame covers the lower points cover screw. Do I need to drill a hole in the frame to remove the cover for points replacement/adjustment?
Old 06-06-2017, 05:01 PM
Lancej1993 Lancej1993 is offline
I just use a short flat head, there is a hole in my frame near bottom one but not direct, maybe from prior owner
Old 06-06-2017, 05:15 PM
Should already be a hole in the frame.... I don't know that I've ever seen a wide frame that didn't have one.
Old 06-07-2017, 04:03 PM
Ash_129 Ash_129 is offline
As mentioned, yes, there will be hole in the LH side frame.
I switched the slotted screws out on the points cover for a pair of Allen headed cap-screws. Makes access, and removal a little easier, I've found. Up to you though.
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
