DSC00395.jpg DSC00396.jpg I've decided to part with my 2182. This tractor has already had the once over by a very SGT knowledgeable member. (He may identify himself if he chooses.) Edit: Sam Mac is the member This is a good one guys. Here is a list of the mods that were performed before I acquired it: -Rear end was taken apart, cleaned, drain holes drilled for axle tubes, and new gaskets. -Rear end support brackets brackets installed. -Custom wiring harness with new aftermarket fuel pump. -Oil pressure, engine temp, and voltage gauges installed. -New water pump installed. -12" wheels with loaded tru power tires. -Deck disassembled, sandblasted, spindles checked, rear mounts modified, casters replaced, and painted. -Rear PTO removed. I repeat NO REAR PTO. -Includes a 3pt to sleeve hitch adapter. I have since installed: -All new steering joints. -A beautiful scotch-guarded, padded, and pocketed seat cover! This tractor has never failed to start in the 2 years I have owned it. Even in the dead of winter. It does smoke some at start up but clears. It also uses some oil. That being said, the motor runs excellent. I do not know actual hours as previous owner replaced faulty hour meter. (it reads 97hrs) What is a fair price..?? Location: Wytheville, VA Contact me at: basheffey07@centurylink.net
1882 SGT 60" Haban deck |
$2600.00
considering the series of tractor and your general location I had no problem figuring out who "the other member" might be....
Sold the old girl.
