Old 06-02-2017, 08:42 PM
RLause's Avatar
RLause RLause is online now
Default Two Dollar Hydro Fix
A month ago I bought a 1864 with 500 hours for parts to fix the noisy hydro on my 782. After replacing the hydro and drive shaft, I couldn't believe how bad it jerked when going from forward to reverse. The trunion had no wear except for the pin that slides in the slot. The pin where it was not worn measured .375" and the slot was .390", the slot on the original was slightly over the .375". After welding up the wear spots, filing them to fit and shiming everything, the hydro shifted pretty good.
Then I got to thinking there must be a better way to remove the slop and play. Then it occurred to me to use a spring to keep the pin from flopping in the slot. I tried it on the hydro that came out of the 782. I drilled a hole for the spring and made the bracket with the 2 holes to hold the other end of the spring. It seemed to work good so today I installed it on the tractor. Went to drill a hole in the trunion and found it is hardened. That must be why it was not worn. Went to plan B with the hose clamp, I figured a tywrap might not hold up. Wrapped it up and could not believe how well it worked. Super!!
The bracket is about 1"x 3/4" by 1/8" with a 3/8" hole in one end and 1/8" in the other. The spring is about 1-1/2" long, 1/2" dia. with .038" wire. McMaster-Carr part #9654K912 is close.
About an hour of work was sure worth it. This will work on all Cub hydros.
Richard
Old 06-02-2017, 09:03 PM
PaulS's Avatar
PaulS PaulS is offline
Have any pictures of that?
Old 06-02-2017, 09:06 PM
RLause's Avatar
Forgot when I posted ..
Richard
Old 06-02-2017, 09:59 PM
john hall's Avatar
Hardened--yes indeed. I tried to bend the one in my 2072 many years ago to get it to line up better, SNAP.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 06-02-2017, 10:10 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I may adapt this idea on a couple I have. I like it! Thanks for sharing!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-02-2017, 10:25 PM
RLause's Avatar
Travis you are welcome. I would be glad to see answer any questions. It works so well for being so simple.
John, the one on my IH 782 was not hard.
Richard
Old 06-03-2017, 07:36 AM
john hall's Avatar
Must have been a revision change somewhere along the way. Anyway it surprised the heck out of me. Back then it was about a $50 part, hate to think what it cost now.
As a point of reference, was your 782 cast iron or alum. rear---just trying to pinpoint about when the change occurred. If it was just a revision to the material then I suppose it won't show up in the parts books, as I would think dimensionally the parts are the same.
EDIT: After looking at the pictures again I think it was the larger piece, the one that goes around the one with the springs in it, that we broke. Sorry about that folks!
2072 w/60" Haban
Old 06-03-2017, 07:46 AM
dale c. dale c. is offline
why not make the bolt on bracket a little larger and just hook the spring into the existing trunion spring hole
Old 06-03-2017, 10:39 AM
RLause's Avatar
I thought that the way the trunnion springs wear the hole bigger, it would wear the hook off the small spring.
John, I just checked Partstree for the correct spelling of trunnion and the price of the shaft that goes into the hydro with the bracket goes for $275. My 782 was built in 1979 and the 1864 after 1993. I've welded several of the square holes in the older ones including the 782 when I got it, but this is my first newer one.
Richard
Old 06-03-2017, 06:07 PM
TIMCRUTCHER TIMCRUTCHER is offline
Or why not fix it right instead of "jerry rigging".
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
