Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 05-22-2017, 03:03 PM
sshirk sshirk is offline
Default 18hp B&S Vanguard in 782
Looking for any information about wiring a 18hp B&S vanguard into a 782.
I have a 782 that did not have an engine and found one that already had been in a 682. The only information the guy I purchased the engine from said all I needed was a 6 prong ignition switch and make the drive shaft about 1 inch longer. The motor mounted right in and I have a switch ordered but not sure how to wire the new switch to the vanguard or what changes I need to make to the current wiring harness.
I don't think this was a kit when he purchased. I have a red wire coming off of the regulator, another red wire that goes into the shroud, and a white wire that is screwed to white plastic on shroud.
any information is appreciated.
Thank
Scott
Old 05-24-2017, 02:10 PM
First, welcome to OCC......
I can help you BUT....I need the B&S Model and Type number before I dive into this. Further, I may take a couple of days before I can draw up a diagram.
If that suits you, then let me know.
Old 05-24-2017, 09:15 PM
sorner's Avatar
sorner sorner is offline
I've done this a few times (wiring a vanguard into another tractor) but never wrote it down. Basically, the red wire from the regulator is the regulated DC charge, the white wire screwed to the plastic is the kill switch, and the other red wire is the fuel solenoid. You're missing the solenoid wire to engage the solenoid to start it, and the lights.
I don't remember off the top of my head which ones go where on the ignition switch, but it isn't too hard to figure out with the right documentation/pictures.
Old 05-25-2017, 02:29 PM
Vanguard V-Twin model number 356447
Old 05-25-2017, 02:53 PM
356477-XXXX What is X...???
What is the Chassis Serial Number for the 782...??
Old 05-25-2017, 05:34 PM
Here are pictures of the data plates on cub cadet and also the vanguard motor I am putting in
356447-0079-F1 is the entire number on the data plate for vanguard engine
143782399 model for 782 serial number2050601U714252
Thanks
Old 05-25-2017, 05:59 PM
Thanks,
I'll get the B&S Diagram.
Old 05-26-2017, 10:59 AM
Picture of wiring from the vanguard book
Old 05-26-2017, 12:50 PM
This is why I'm glad Roland has the patience for this.
Old 05-26-2017, 01:00 PM
Diagram completed and sent.
