Old 06-05-2010, 05:44 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Default Changing Oil
Does anybody have a good way to change the oil without running it all over the belt and subframe??
My yard looks like the Gulf.
Pat Benner Haskell OK
Old 06-05-2010, 05:48 PM
Yeah, take off the deck and subframe.
Old 06-05-2010, 05:54 PM
Amigatec's Avatar
I am going to try to build a pipe and pan setup that will fit under it. I tried a short piece of PVC pipe and that didn't work. I may add a 90* fitting to it.
Old 06-05-2010, 06:35 PM
fer100's Avatar
fer100 fer100 is offline
my ariens 934 Hydro has a elbow and piece of pipe and cap attach to the oil pan that extends beyond the frame. I've was wondering if this would work on the Cubs. I've had this mower for 11 years now and no problems.
,1 Ariens 934 Hydro with cyclone rake
Old 06-05-2010, 06:40 PM
Amigatec's Avatar
I added one to my Snapper, but it always worried me.
Old 06-05-2010, 10:10 PM
Amigatec's Avatar
I mow about 6 hours every week, so I add up a lot of hours. It seems that every time I need to do something I have to remove the deck.
Old 06-05-2010, 10:16 PM
Amigatec's Avatar
I think I have found the perfect thing to use. I am digging a trench to run a conduit and electricity to my Chicken Coop and I tried a 1" PVC conduit elbow and I think it will fit.
Old 06-05-2010, 10:40 PM
I've used a small funnel and hose before, but sometimes if overflows and is a little messy. Most of the time it works fine though. The PVC sounds like an interesting option to explore.
Old 06-05-2010, 11:04 PM
fer100's Avatar
The elbow and pipe thats attach here is metal. My only concern with pvc is that if it gets caught on some thing it would break real easy. Then the engine woud seize. Even with the metal I'am still very careful when I use the machine. Removing the deck is alot easier than replacing a engine and less costly!
Old 06-06-2010, 03:50 PM
Amigatec's Avatar
Here is what I came up with. A piece of 1" PVC Conduit Elbow. Should fit with the deck up or down, might still be a bit messy, but it's better than draining the oil in the grass, and all over the belt.
