Old 05-13-2017, 12:49 AM
Ronnie125's Avatar
Ronnie125 Ronnie125 is offline
Default 1450 heat shield bolt size?
I recently acquired my second Cub, a 75 1450. I installed the heat shield box, but I am missing the little bolts for the threaded holes in the top of the aluminum piece that secures the steel box. What size are these?
Also, what size belt do I need to go from the PTO to the 44a deck? Thanks.
Old 05-13-2017, 01:01 AM
http://www.cubcadet.com/equipment/AR...0-A/0024800005
http://www.cubcadet.com/equipment/AR...0-A/0074200001
You need to go to these pages, then play around on cubcadet.com. You need to be able to look up your own parts. I personally don't mind to help a newbie, but seriously.... anyone can look up these parts. I won't do it for you anymore. If you have a question because it isn't clear, or the part is NLA, then ok.
Old 05-13-2017, 02:54 AM
Ronnie125's Avatar
Cool
You must have me mistaken for someone else, I've never asked anyone to look up anythimg for me. Thanks
Old 05-13-2017, 03:23 AM
I made no mistake.
And now that you know where to look, you won't have to again.
Old 05-13-2017, 04:04 AM
Ronnie125's Avatar
I already have the parts diagrams and all associated manuals for both my 125 and 1450 downloaded. I asked because the parts diagram lists several screws, but not the locations. I just need to know which size screw goes in those 2 holes. I used my own screws, washers and nylocl nuts to assemble and install the box.
Please do not talk down to me like I'm an incompetent idiot. I asked because I did not know.
Old 05-13-2017, 04:59 AM
This just got interesting.
I wasn't talking down to you.... but your starting to irritate me.
It's a hole that takes a screw. There are only about 3 choices of bolts listed in the book. How hard is it to find the screw size that goes into the hole? You have the book and the tractor in front of you (plus I linked you to the electronic parts book) and it lists all the bolts needed. You can eliminate the ones that are too large or don't make sense. (Like if the bolt length listed is 1.5" long, and you need a short screw, it probably isn't that one.) It lists the size of all the bolts. Plus it lists the quantity you need!!!! If the hole is small, it probably isn't going to take the 5/16" bolt now is it? Besides, I'm not there looking at which hole your trying to fill. How the heck am I (or anyone) supposed to know which one you need???
Good grief.
Oh, and a nyloc nut will melt the nylon out when the engine gets hot.
Now, the belt. You said you have the parts book. I listed a link to the electronic one. It lists 3 different belts. It lists tractor serial numbers. You have a 1450. It will have a serial number somewhere between 530001 and 664996. So.... now there is only one choice. Buy that belt.
Old 05-13-2017, 10:03 AM
The screws, bolts, washers and related hard ware to each part are listed right below each said part in the listing below the exploded view of the ass'ly in question.
Can't get much simpler than that.
Old 05-13-2017, 01:57 PM
Ronnie125's Avatar
I sure wish I was in the barn with my Cubs in front of me! I'd be much happier, but I'm not. I am 500 miles away from home.
