I hope this is in the correct place and not another we have heard it a hundred times posts. I know how frustrating it can be. I have a 1966 Cub Cadet IH 122 with the high low on it. I hope someone can help me fruuuuuustrated and smashed a finger, we have all been there. So I bought it a few days ago and it drove ok for age, I started up a small incline and it felt like it went into neutral. So I check everything, shaft is spinning nothing being produced to the rear. So I figure from the posts it is the pin in the rear no such luck. As much as I didn't want to do it I split the rear from the tractor. What confuses me is after taking it apart I lifted the front of the transmission up while in gear and the short input shaft was spinning. I can take the short input shaft that goes into the transmission spin it by hand and the rear wheels move. Also the clutch was not slipping. Any help would be greatly appreciated. Thank you.
Did you remove the creeper? There is another pin inside.
sounds like the creeper handle pin came out of the collar inside. It's common. When this happens it's normally stuck in between ranges
I didn't remove the creeper yet but will. The only thing that didn't make me think that was is it was the moving the rear wheels when I turned it manually.
The shifter for low and high moved freely from low to high. The lever looks like it runs all the way through from left to right. It there an exploded view of the creeper or who made it? |
It was made by IH, and you can find an "exploded" view the same place you find any of the parts pics....cubcadet.com. Upper right corner, click "parts and service" then enter your model number, then choose the part assembly you want to look at.
Thank you. I'm new to this page and cub cadets.
![]() ![]() ![]() You gotta start sometime, no time like the present. ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
