Old 04-20-2017, 08:38 PM
tar1962 tar1962 is offline
Default Miller Tire Surprise
I am confused after mounting new tires on one of my 1250's. I own three 1250's two of which still had original front tires. Of the two with original tires one is a 1975 with 3/4 inch spindles and the other is a 1979 with 1 inch spindles. The '79 had serious balding issues and so I purchased a new set from Miller Tire. The former owner of my '79 took excellent care of this machine and I was aware that he had put 1650 sized tires on the rear. The front tires, although balding, looked the same size as my other 1250 that also still had original front tires. The size on both were 16x6.50-8. I ordered a pair of the same size Carlisle Rib 4-ply. These are tubeless but I put tubes in anyway due to the terrain I deal with. When I mounted them and put them on, the two tractors were within 4 feet of each other, however, the new tires looked like I am running a pair of blow-up spares compared to the original front tires I removed and the original tires still on the other tractor. The pressure is correct on both pair but the new tires are smaller. Same size but very noticeably smaller. Now I am thinking I should have bought the V61's but I have no idea if they would be the correct size once mounted. Has anyone on here had this occur or are the V61's and the Carlisle Rib 4-ply just made differently? I can't stand the look of the ones I mounted but before ordering V61's I thought I would see if I could get some better info than the forum photos and info I thought I had correct. I had read forum recommendations for both of these tires from Miller but there is something wrong about the Carlisle's I chose. I want to match the original look and I do plan on asking Miller what the difference is but I figure you guys are the experts from a Cub Cadet standpoint. Any help would be very appreciated!
Old 04-20-2017, 10:14 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Pics of both tractors would help.
Edit: paragraphs would help read that mess too.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-20-2017, 10:23 PM
16x6.50x8 is the correct size. Probably just a difference in brand.
Old 04-20-2017, 10:59 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Lawn and garden tires actual dimensions vary widely from manufacturer. I have had tires vary in dimension from the same company. When I purchase tires for my QuietLines, I compare each one to ensure equal size.
Queen Of The Quietlines!
Old 04-20-2017, 11:00 PM
I would agree with Jon on the brands being the issue. Just because the tire size is 16x6.50-8, the only certain is the 8" wheel size...
Old 04-20-2017, 11:36 PM
I purchased these tires based on forum info after months of research on multiple forums.
Two specific tires from Miller were suggested multiple times on this and other forums.
I was not going by just tire size.
It is a shame that reproduction tires are not readily available.
I just wanted it to look stock and match the deck set-up within reason.
I can't see where pics would help. Sorry about not paragraphing correctly.
Thanks for your help guys.
Old 04-20-2017, 11:59 PM
Shrewcub's Avatar
I'd just like to see how big a difference we're talking. One guys 6 inches is totally different from another's.
And paragraphs help my drunk a$$ eyes stay focused.
Sorry 3 forums steered you wrong.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-21-2017, 01:32 AM
New tires just like OEM are available. I've bought them. Maybe what you think is OEM on your tractors, isn't.
Pictures would help......
Old 04-21-2017, 05:52 PM
If I'm following what you are talking about, I had the same problem on my 147 when I bought the same tires for the front. I had bought one in 2012 and then bought another one in 2014 just to notice, although the tire size was the same, it was a smaller tire. I contacted Carslile about the problem and they sent me another tire. I ended up putting two new tires on the front of my 147 and I was happy with it. My guess is that with a bit of age they grow in size about 1-2 inches.
Old 04-21-2017, 05:59 PM
Shrewcub's Avatar
You may have
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Tags
1250 front tires
