Thread Tools
Display Modes
Has anyone on here installed an electric lift on a Cub 100? I have all the components from a Cub 147, except the switch and frame bracket. I would need a photo and dimensions of the bracket from someone who has one mounted on a narrow frame other than a 147. I have seen a photo of a 127 and the bracket looks like a flat piece of steel bolted to the frame.
The electric lift and brackets were the same for all the narrow frame tractors. Doesn't matter if it's on a 127 or a 147. Same.
Sell the lift to someone who needs it for a 147. It isn't worth the time to mount. They are slow. |
![]() Quote:
I slow too. I have a 147 with electric and am happy with it. |
![]() Quote:
http://www.cubcadet.com/equipment/AR...0-A/0019900008 |
![]() Quote:
I didn't realize they were welded to a 147.
Oh well. I still don't see why you need to make one exactly like what was used. Nothing to a bracket. Just make one that works. The 100 didn't come out with e-lift, so what does it matter if the bracket is exactly like the one that would have came on an e-lift. But I digress. Maybe someone will get you the dem's and you can make it. |
![]() Quote:
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
How about a cup holder?
How bout a hydraulic cylinder?
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
