Old 04-17-2017, 10:46 AM
IHcubcadet1's Avatar
IHcubcadet1 IHcubcadet1 is offline
Default Original still leaking oil from the head..
Hello guys hope you had a good Easter,
My original still leaks oil from the head. Is there such thing as resurfacing the head too much? I got a new gasket when I restored it this winter. And torqued the bolts with sequence. It has blowby. Do you think that's my problem is too much blowby? Just thought I would let you guys know. You know more than me!
Thanks guys
Noah
Old 04-17-2017, 11:02 AM
Did you retorque the head after the first heat cycle?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-17-2017, 01:30 PM
No.
No
I also want to know that.
Old 04-17-2017, 03:31 PM
Noah,
What kind of head gasket did you get? If it doesn't have that seal around the inner perimeter, then your oil problem might be from the oil leeching through the lining of the gasket. Go with quality parts when replacing parts on your tractor or you get the reward of doing them over.
Old 04-17-2017, 04:04 PM
Noah,
Oil shouldn't be on the inside of the head gasket anyway...... unless the motor is shot. I do concur though.... head gaskets without a fire ring are junk.
Old 04-17-2017, 04:56 PM
Yeah, too often people sacrifice quality for saving some change not realizing the long term costs is always more. I wasn't having a memory loss and forgot it was called a fire ring. I think the Stens gasket is alright to use, but it has been a couple of years since I had to change one out.
Old 04-18-2017, 08:26 PM
Thanks guys for the input. I've been busy with an old Deere A. I will retorque after it's done warming up and will post pics of the gasket on it now. Thank you it mostly leaks where the exhaust port is from the engine. I will start on it and show you the gasket.
Thanks
Old 04-18-2017, 08:35 PM
No, don't take the head off. If you do that, you'll have to replace the gasket. Can't use them over.
Old 04-18-2017, 09:08 PM
I will order a new one then, not that hard. Any suggestions on a good website or name that you guys go with. Instead of the amazon cheap ones?
Old 04-18-2017, 09:11 PM
From Cub Cadet. Item number 56.
http://www.cubcadet.com/equipment/AR...0-A/0118500003
