Old 06-02-2010, 05:47 AM
nikster's Avatar
nikster nikster is offline
Default Hydrostatic fan question?
Good gosh, not too much left of the fan.
I imagine this has been there for awhile? It has 1 fin left. Going to replace it but am wondering how important is this fan? There is a reason behind it but I don't have a clue if this fan is that effective or ?
Maybe some one can chime in about the effect of this fan who knows something about it.
for any imput.
Nik
Old 06-02-2010, 06:30 AM
dyt4000's Avatar
dyt4000 dyt4000 is offline
It was put there for a reason...to cool the hydrostat transmission. It needs to be replaced.
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 06-02-2010, 07:04 AM
TEET's Avatar
TEET TEET is offline
DYT is correct...it is there to aid in cooling the hydro pump and tranny. I would definitely replace it as soon as possible. One of our sponsors above, or your local cub dealer should have one for you. It also looks like your about to lose a bolt from the rag joint...looks pretty loose to me.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 06-02-2010, 09:12 AM
nikster's Avatar
Yes I had intended to replace the moment I saw it. It seems that the gentleman that used it previous had run it that way for a long time?
After I get the rear fender off & I power wash it, I'll have a better idea as what i'm going to replace or ?. One thing is that when I removed the back plate for the tranny & popped the plate, I saw that the fluid almost looked new.
Nik,
It may not look like new oil in the photo, but I would say that it was replaced last Fall?
Old 06-02-2010, 04:36 PM
Amigatec's Avatar
Amigatec Amigatec is offline
I can stand behind mine and feel the air from the fan, so it does some good.
Pat Benner Haskell OK
Old 06-02-2010, 05:06 PM
IT's also fun to get your mom to yell at you, because you left the cub running, while she's over a pile of dirt, The dust that the little fan makes is INCREDIBLE.
Your cub Looks like she's been loved, and used everyday
Thanks
Cody
Old 06-02-2010, 07:13 PM
If you haven't already, pull off the fenders and degrease the pump...the fan won't do much good if the cooling fins are not exposed to airflow.
Old 06-03-2010, 07:33 AM
nikster's Avatar
Jeff (teet)
What a eye ya got.
Checked it out & yes it was loose.
Thanks,
Nik
Old 06-03-2010, 09:34 AM
bvanzalen's Avatar
bvanzalen bvanzalen is offline
I need to replace my fan also. Is there a link showing how to get the drive shaft off?
Bob VanZalen
1974 Cub Cadet 169
Old 06-03-2010, 09:38 AM
nikster's Avatar
[QUOTE=bvanzalen;31390]I need to replace my fan also. Is there a link showing how to get the drive shaft off?[/QUOTE]
Not there yet, but would be helpfull.
Nik
