Old 04-14-2017, 07:55 PM
pennsdalerepairshop pennsdalerepairshop is offline
Default 2140 Electrical Problem!!!
Guys...need help here, please...
This 2140 does not engage the PTO. Switch good, clutch good, wiring OK. fuses OK. Voltage regulator puts out at least 35 VAC running, ZERO DC output. Ohm test on each lead (disconnected) shows infinity on AC leads and shorts to ground on center DC lead. Tried another VR; not exactly the same style (off a JD 318 with Onan P218G); same result. Thinking stator bad?? I'm at a loss here.
What am I missing???
Old 04-14-2017, 07:59 PM
Not likely...
Here is some data typical to your situation.... Charging System
