2182 kubota gas - Quitting when pto engaged, if you engage then release quickly then re engage it is fine, seems the govenor need adjustment, hard to find info on gonvenor adjustment, originally thought electrical issue when deck was engaged but not the case, seems to bog a little when engaged thus killing the engine, thought deck was tight or something but not the case, possibly high speed jet ????
Thanks Curt |
I know this sounds harsh but they like wide open when you engage the PTO ask me how I know.
I find that if I pull the choke out about a 1/4 pull it helps on mine. Especially when cold.
1882 SGT 60" Haban deck |
seems to be some interesting info there, i played with the govenor a bit and it seems to help, funny, there is a lot of stuff to turn when you engage the deck, everthing is heavy and takes a bit to get everything moving, wonder were they like that when new ????
