Does anyone know where I can find king pin bushings & bolts for a 782
I think the part #'s are 750-3002 for the bushing 710-3020 for the bolt Thanks, Daryl |
You can find parts at:
* Your local Cub Cadet Dealer * Your local Case/IH Dealer * The Sponsors list at the top of this page (Patton or Houtz) * And numerous sources all over the Internet
Thanks,
They aren't available at the dealers anymore |
Many models of Tractors used those parts. I would look at Patton or Houtz above, for some good used parts.
Those parts were used on these models: * all of the 1x8/9 Series * all of the Quietline Series * all of the 82 Series * 1204, 1210, 1211 * 1604, 1606 * 782D, 882, 1512 Diesels * 580, 680 * 17xx Series * 18xx Series
This guy has what you want.... http://ccspecialties.org/steering_seats.html
Scroll down until you find the part numbers. You can also buy a kit....712-3012.......>>> 912-3012
Thank all of you very much that was the info I needed.
I had been searching the Internet without success trying to find these parts. |
![]() It's a fine thread bolt, with a hole drilled in the end for a castle nut. Just buy a bolt and drill a hole. Make a bushing. That's about as easy as it gets. You can order a bolt from: McMaster Carr, or Fastenall.... or anywhere you want on line. You can also order bushing material from McMaster. Or you can have a machine shop make one. |
Roland, that's just the nut, not a kit.
The kit is $28 from cc specialties.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Here is a picture of the Kit I was referring to....
