Old 03-31-2017, 08:04 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Thumbs up Getting in deeper 1650 loader+powersteering
In my other thread on the 1650 with loader I just bought I had to remove the head to replace a blown head gasket. Since I was this far I might as well replace the iso mounts so I removed the engine. I then seen that the drive coupling and flex disc joints needed replaced so I removed the driveshaft. Then yesterday I picked up a parts 1864 from member RLause, (Thanks Dick) and decided to use the power-steering and super steer axle from it on the 1650. I got the steering box mocked up yesterday evening and installed the front axle and steering cylinder. The axle slipped right in, and to mount the cylinder all I had to do was drill out an existing hole in the frame and drill one new one. Today I will make up the hydraulic lines and make a coupler for the steering shaft and mast jacket. I will get some pictures later today. I was surprised that it was almost a bolt in operation. Also I was able to modify the 1864 steering box bracket to use the existing manual steering box mounting holes on the frame. This is an easy swap for any wide frame tractor with a ported pump. I might just learn to like a quietline when I am done with this upgrade.
Keep you updated as I go.
Tom
Old 03-31-2017, 08:18 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Mm, your in no way the first one to put power steering on a quietline, however, I would be interested in seeing how the super steer axle looks on a ql.
Power steering is awesome! And the super steers are the best. You'll like!
1- 1200 in pieces
1- 1864 in pieces
Old 03-31-2017, 08:26 AM
Woodward makes the coupler you need. C109 is the part number. Then all you need is a section of muffler pipe expanded just enough to slip over the lower part of the steering box. Link to Woodward. http://www.woodwardsteering.com/
Old 03-31-2017, 09:55 AM
RLause's Avatar
RLause RLause is offline
Way to go Tom. Sounds like you were burning the midnight oil.
Richard
Old 03-31-2017, 12:06 PM
Merk Merk is offline
Adding power steering is one of the things I wanted to do to my loader tractor. I'll have to watch this thread to see how the power steering works.
Project Uncle Dick
Cub Cadet 70
Old 04-01-2017, 08:26 AM
Well I finished up the install of the 1864 power steering components yesterday and started running the hydraulic lines, the cylinder hose connected right up as expected and if I was to remove the lift cylinder the lines from the steering valve to hydro would also work with just adding a coupler and removing the return from the control valve tee. To save making all new steel lines I am thinking of eliminating the lift cylinder for now so I can get this finished up for now. With the weight box on the back the lift is not usable. If I decide to keep the loader on the 1650 and want a rear lift I can always add a rear lift cylinder in the back like I did on my 1872 project. Sorry no pictures yes as I left my phone in the shop last night.
Later
Tom
Old 04-01-2017, 09:02 AM
ambrola's Avatar
ambrola ambrola is offline
Lets see some pictures Fred.
Old 04-01-2017, 11:15 AM
Jumper Jumper is offline
Tom, we need those pics!
Old 04-01-2017, 08:23 PM
I agree! Looking forward to your pics.
Old 04-01-2017, 09:37 PM
I finished up the hydraulic lines for the power steering conversion today. I was able to reroute one of the lines and made a couple new ones and I now have the stock hyd control valve hooked up to the lift cyl. I had a nice visit from member Merk and his wife today. He wanted to get some measurements from the loader subframe for the loader install on his 149. Glad I was able to help him out. Here are the pictures, enjoy.
Tom
Front crossmember was damaged, Repaired and welded in new pivot bushing, steering shaft coupling made from old GM steering column.
steering shaft welded to coupler, modified 1864 mount that bolts to stock steering box mounting holes on frame.
Column tube splice. clamps to steering box with muffler clamp, view of cteering cylinder bolted to frame using one existing hole and one new one. The hole in the frame was the only modification to the stock frame to install PS.
Close up of cylinder mount, Hydraulic line routing
Super steer axle view. I plan on adding 18X8.5X8 tires and wider rims since I now have one inch spindles.
Later
Tom
