You need to replace the ones that are on the engine currently with the pulleys in the second picture
Ronnie that looks like the front of the 7 horse on my 70. Not sure about originals but mine has a lever on the side of the pedestal with a rod going out front to engage the PTO clutch. Yours does not have a PTO clutch.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 ![]() ![]() {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Ronnies has constant running mid pulley deck with actuator built into the deck, he needs to swap pulleys
If it came to you like that, with the original pulleys in a box, i would be concerned there is a problem with them. Maybe the pulley was loose because the bore is wore out, and they put the basket pulley on as a cheap fix. Only way to find out is to swap em....put some shoes on first!
![]() Bill |
![]() Quote:
![]() Quote:
They made a retrofit kit that used the pulley with the clutch system the release arm is only for an Original..It was so you could use a newer triangle deck on it.Or for a tiller
![]() Quote:
Are you referring to the one on it now? I assume with this being a 4 digit machine, it would have had the 2 pulleys as shown? |
![]() Quote:
![]() Bill |
