Old 02-23-2017, 10:37 PM
chevysbest92 chevysbest92 is offline
Default Cub cadet 2172 repower question
Hey guys, I'm making some progress on the Kohler command 20 swap into my super 2072. I'm just wondering if someone could help me out on the wiring. I'm pretty good with wiring but I don't want to screw anything up on my donor motor. So what exactly does each wire do coming off the engine, it's a ch20s.
The plug off the engine goes... One white by itself. A red and purple together. A red and blue together, and a green by itself.. Also is there a certain key switch or relay I'll. Need? My 2072 never came with a motor and the wiring is a mess, so I just want to get some insight
Old 02-23-2017, 10:58 PM
RLause's Avatar
RLause RLause is offline
The wiring is covered in the service manual. It is available on the Kohler Engine site.
Richard
Old 02-24-2017, 12:44 AM
I'm aware of that. Everything is on the internet. I'm looking for human insight . I. E. What does what, what needs power and when. Are certain relays needed for a swap. Is a specific key switch important Thanks though
Old 02-24-2017, 06:37 AM
Leadslingingdaddy's Avatar
Should try the search button first...
http://www.onlycubcadets.net/forum/s...command+wiring
Old 02-24-2017, 09:04 AM
Thank you, that's what I was looking for. My search on the forum isn't working, so I've been trying to use Google to do the search through the forum
Old 02-24-2017, 09:07 AM
If you were good at wiring like you say, then you don't need someone to tell you. A diagram from a book would be good enough. So.... what you really meant to say was your very good at hooking wires together, as long as someone tells you were to hook them up.
If the link Leadslingingdaddy posted doesn't answer your questions, then I'm not sure we can help you.
