I figured I'd start an official thread on this project, my goal is to have it done and plowing at PA plow day which starts April 21st. What I'm basically building is a 129 with the dash and controls from a 1450, this tractor will have dual hydraulics and a cat O hitch. I would also like to build some fake axles that stick out to simulate a larger tractor, once there made I plan to fill them with cement to add some extra weight. Once it's all done I plan to top it off with a red and gold paint job like the demonstrator tractor pictured below. If time and money allows i would also like to convert one of my brinly plows to cat O and give it a matching paint job.
I started the mock up today, I started by removing the rear end from the 1450. The rear end is very dirty so it will be getting some new seals and the trunion is in need of some serious help. Once the rear end was out I switched the brake pedal from the 1450 into the 149 donor frame, the 1450 pedal sticks out further from the frame as seen in the pics below. I've had a rebuild kit and a cut crank sitting here for a while so fortunately I don't have that expense right now, I grabbed a bare block off the self and will be dropping it off at the machine shop tomorrow. i plan to put this entirely together so i can make sure the rear end functions as it should and to test fit the sheet metal, i will probably barrow an engine from another cub for the test run.
I like the idea.
![]() Got to admit you Yankee boys are tough! The darn thing has snow on it and you are already turning wrenches on it. If that were me, you'd find it in the shop warming up and drying off first! So if this one turns out nice, I think you should get a 70 or 100 and make a white demonstrator C out of it, narrow front of course ![]()
I plan to stick with all cub sheet metal, mwsc has the tractor style fenders but they are aluminum which i don't want on a working tractor, i'd also like to keep cost to a minimum. The red will be case/ih paint but the gold will be base/clear.
That's the thing about a custom build, it can be as simple or complex as you like. With a 3 month window, you are probably better keeping it reasonably simple. So, are you going to 2 tone the rear rims? I vote yes, don't want to see you get off too easy!
![]() Quote:
Tim, I think your creation will be awesome!
![]() Queen Of The Quietlines! ![]() |
Sounds interesting, and tasteful. Some try their version of a modified paint job, and well, should have left it as it was instead of ruining it. But we all have to learn to crawl before we could walk...
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
