Old 01-29-2017, 02:59 PM
Huminajumina Huminajumina is offline
Default First Post!! PTO Rebuild with Question?!?
Hey everyone, I have been a member for a while, but haven't made any posts yet (or at least I don't think I have).
I used to do garden tractor pulls as a kid, and towards the end of that time, my father finally got two Cub cadets to use a 108 and a 126. Once I moved out years later, i took the tractors with me to mess with and try to get them back to working condition (yard working condition).
I have worked on many projects over the years: Airplanes, FJ40 Landcruiser, S10 Pickup, and a fleet of Motorcycles....now I am finally getting the cubs running.
So I had to rebuild the PTO on the 126 and I haven't really found a definite answer out there...I know it is on the forums here somewhere....
1) Is that the correct spring on the PTO for a narrow frame? or can it be used?
2) It seems those style springs always come in 2's, should I have used two?
3) On this style of PTO, when using the tool to set the tension (per the manual) Should the tool be setting on the same surface that spring is on (outter most) or should it be setting in the recessed lip (where the throwout arms are)?
The manual even shows a picture of this Narrow Frame style PTO pulley with both styles of springs installed. I will keep searching the forums for a better answer, but I know someone is much more experienced with this than I am. I want to avoid necessary wear or breakage if I can.
Thanks in advance for any help.
Kevin
