Old 01-19-2017, 08:45 PM
john hall's Avatar
Default I got a "plastic one" !!!---2284
Yep, I done gone and got me one them plastic lawnmowers! Last year I decided I had more mowers than we need to use--but I sure wouldn't mind having one of those great big cyclops Supers---if a cheap one came along. Tues night I did a no-no. Pulled up CL and typed in Cadet. Up popped a 1450 Cadet--but it sure looked like Cyclops to me. Going to Cadet's website revealed it was a 2284. Price was cheap---my kind of cheap (as in very). Looked a little rough, didn't run. I emailed the guy and he texted me around 10pm. Arranged to go look at it yesterday but he had a family emergency. He promised to hold it till I got off work today. In the meantime I sent the ad to Sam Mac. I figured he'd give an honest opinion and not buy it our from under me. To paraphrase Sam, he'd be all over it. I was hooked, if I couldn't find anything horrific, it was going 15 miles north.
I really need to pause and thank Sam for being a GREAT guy and not buying this behind my back since it was well within driving range for him. I'm sure I'll be making a pest of myself asking questions.
I had a buddy come over today to help dad get the trailer hooked up behind dad's truck. Dad met me after work and we set off on yet another adventure. When I got there it turns out the guy flips late model lawnmowers, and he has some REALLY nice looking stuff. I was drooling all over a Cadet Tank with a new engine and immaculate original paint. Must have had 15-20 other mowers of all brands for sale. All were fairly new and in above average shape--guy has an eye for quality. This machine did not belong with the rest of his stuff. He actually traded for it. Claims he didn't have time to fix it with all the other work he has to do so he put it for sale cheap.
Guy had removed the PTO clutch trying to figure out why the engine wouldn't turn over fast. Don't know why he didn't just take the belt off. The guy he got it from pulled the right side valve cover--broke a bolt off in the process. The 2 of them are convinced there is something wrong with the camshaft/valves. Even though the starter would barely spin it over, you could tell it didn't have a broke rod (both sides appeared to be compressing air). I noticed a bolt out of the starter and the other one appears to have been out recently, seller didn't know anything about that. The grill is cracked at the bottom--he pointed out the side panels are what is holding that on. Tires look good, front axle seems fairly tight, power steering doesn't appear to be leaking. Rear end looks dry. Air filter looked about new. Dash has some cracks. Seat is a mess and safety switch unhooked. Deck needs a little help--loose bearings. I think the key switch is buggered--key fits real loose.
Got home and couldn't stand it, had to hook up the charger. Well, turns out it has a huge battery (for a lawn mower)--over 575 amps. Wouldn't you know it, positive cable is loose and dirty. Rolled out my big charger and it went to spinning a lot better, but not great. Pulled the valve cover removed by the PO and all looked well, other than the bolt I have to drill out. Pulled plugs and have 100lbs compression each side. Seems low, is there a compression release in play here? Maybe valves need setting? It has oil in it so nothing to do but squirt some penetrating oil in carb to see what happens. It tried to make a little noise, sure the lube was good for the cylinders. Decided I needed more bang and used some starting fluid. Got a pop or 2, even seems it tried to kick back on starter. I'm encouraged. I think next we'll pull the starter and check the connections, as well as the rest of the wiring. Then I want to see how strong the fire is. Get it spinning and get fire, it should run--maybe just not well. I'll deal with the fuel system once I know it runs. Probably pull the engine for cleaning, it is quite dirty. I just want to know it runs before I tear it all apart and invest money into it.
By not ever owning one of these, I have generally ignored the threads about this series. Now I'm doing a bunch of research of old threads. Sam and Dirty Steve are now 2 of my favorite authors! I highly doubt this will be as nice as what those guys have done. My goal is to make it mechanically solid and reliable. And then to use the heck out of it.
Now here is the problem--not enough shop time. I've got some MUST do farm projects before I can do much with this one. I'll probably tinker on it a little the next few days while finishing up the 1811 (hopefully). Then it will probably have to go into storage for a while.
Surprisingly, dad didn't pitch a fit about me buying this. All I had to do was to say bring the truck and he was ready to go. This one was built 3-4 years after he retired. He seems enthused about learning something new--at 86 yrs old.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-19-2017, 08:57 PM
That's "super" nice John. I was actually reading the comments on the Craig's list ad and realized you got it. Was hoping you would post about it, thanks for the story and pics. How many hours on the clock?
Old 01-19-2017, 08:58 PM
Dirty Steve's Avatar
Congrats on picking up some plastic, John!
Old 01-19-2017, 09:04 PM
ccguy's Avatar
ccguy ccguy is offline
Great pics of your Dad! When I'm 86, I hope that's me!
Oh, nice monster 2284!
INTERNATIONAL HARVESTER
- A Great Farm Heritage Comes Home.
1811/682/782/1440/IH #4/IH QA 42"
Old 01-19-2017, 09:08 PM
Terry C's Avatar
Terry C Terry C is offline
You're going to love mowing with that! No substitute for power steering and a tilt wheel!
Congrats.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-19-2017, 09:20 PM
Good grab John, Dad looks like he was impressed with your new toy.
Up to 534 and counting...
Old 01-19-2017, 10:02 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Good for you, looking at those pics, you won't have to do too much, Dad may just take over the restore for you........and then take over the tractor.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 01-19-2017, 10:44 PM
Congrats on the new to you super John.
Good to see your pop's is interested...
Old 01-20-2017, 07:09 AM
John
Welcome to the Cyclops club.
Here is some reading for you. http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Kohler CH's have hydraulic lifters, no valve adjustment. Pull the spark plugs and see if it turns over. I'd also pull the valve covers and check to see if every thing is OK on the top end.
Your lucky I am in the middle of an 1864 or that 2284 would be in my shop, LOL. Just kidding I promised you that you had first shot at it. If you had passed on it I would be on the way to get it.
Old 01-20-2017, 08:56 AM
Congrats John. Great pics of your dad helping in the check out of the new machine. I bet your dad will like driving that one with the adjustable seat and tilt wheel. That is one of the nicest Cyclops I've seen come up for sale in the south and it was priced way under its value. I'm glad that one of "us" got it too.
