Old 01-03-2017, 10:58 AM
jerkin jerkin is offline
Default 1864 whine
This 1864 I picked up earlier this summer is my first hydro. Is the whine normal? Can barely hear it at low rpm's but once you raise the throttle it's very noticeable. Worse when cold and gets better as it warms up.
I have not changed the fluid in it yet but it is crystal clear and the filter is pretty clean also. I'm thinking it was changed recently but I need to do it again just to be safe.
Old 01-03-2017, 11:03 AM
The whine is normal but I would change the fluid/filter anyway, you may find its a bit quieter.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-03-2017, 11:39 AM
Yeah, I'm planning to. I have the part numbers written down in my wallet for the filter and type of fluid but just haven't bought them yet. Bought this back in June I think it was after my 582 blew up and then ended up in the hospital for 2 weeks and fell behind on everything so I'm just now getting caught up. Luckily it was in pretty good shape so there wasn't a lot that needed done.
I have the deck off now so I plan on tearing it apart and painting it over the winter. Still a few little things that I'd like to do, replace all the fuel lines, new wheel bushings in the front wheels, etc. Tractor has 900 hours on it so it's been used but not abused.
Old 01-03-2017, 12:43 PM
NAPA 1410 or Wix 51410 for the filter. 7qts. of hydro fluid. Also make sure your deck lift control is centered, sometimes if they are sticky and stuck part way in up or down it will make them howl.
Old 01-03-2017, 09:08 PM
CubDieselFan's Avatar
Mine was very loud, the fluid and filter changed made a big difference.
Old 01-03-2017, 11:26 PM
Just out of curiosity, how did your fluid look when you changed it?
You guys talked me into, can't put it on hold any longer, lol.
