Old 12-21-2016, 05:17 PM
Default One More...
Well, I found a good deal on a 147 in my area so I picked it up. Needs some work, but it's got solid bones. First item of business will be a wiring harness cause this one is rotten, like is prone on the 6/7 series. Then I need to find a lift for it. This one had been removed at some point. PO said he would let me know if he comes across it somewhere. It was given to him by a friend after being in storage for 5+ years. Has the sleeve hitch, spring assist, and all the lights are there. Here's to hoping I can make it nice again
Old 12-21-2016, 05:27 PM
Nice find sir lancealot,
You will be able to find a regular lift arm easier than the Elift which can be pricey.
Hydro lift would be betterer.
Up to 534 and counting...
Old 12-21-2016, 05:30 PM
Looks like a good deal. I have always be intrigued by the 147.
Old 12-21-2016, 05:33 PM
I agree with Lew, I'd find a manual lift since it has a spring assist. Congrats on the new cub.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-21-2016, 05:59 PM
147s are awesome. Love mine. A PO had removed the e lift way before I bought it and had installed an armstrong lift (manual) that works great. I went and put a spring assist on it and it helps. I'd love a hydraulic lift but everything I've read says that the 147 frame is slightly different than the narrow frames (not counting the cut out for the flywheel) so drilling of the frame is necessary for the hydro lift.
Old 12-21-2016, 06:33 PM
EricR's Avatar
EricR EricR is offline
Very nice there Lance, yeah a 147 will be in my stable in the future but congrats on yours!!!!!!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 12-21-2016, 06:40 PM
Looks good Lance. Everything accounted for, good pick up.
Tis the season. Your brother is right, lots of people getting rid of stuff for good deals for extra Christmas money. Can't say I haven't done it myself
Old 12-21-2016, 07:18 PM
Congrats on the 147 Lance, looks good!
Old 12-21-2016, 07:19 PM
Pretty sure you have to drill any of the frames to add hydraulic lift.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-21-2016, 09:11 PM
cadzag72 cadzag72 is offline
Tim, I don't know if the other series tractors are like this, but I know all my tractors have the holes pre-drilled from the factory ( on both sides no less!) That's all 3 of my 125's and my 72. When I put the hydro lift on 125 #1, it was an easy bolt-on affair. I have a 107 frame kicking around, I'll see if that is pre-drilled or not.
Ian
