Old 12-20-2016, 04:25 PM
ljlandscaping ljlandscaping is offline
Default 450 blower on 782
Hi,
I am having some trouble with my lift set up for my 450 blower, it only seems to lift 1" off the ground. Does anyone have pics of there 450 set up on a 782 so I can see what's wrong with mine...
Thanks,
Liam
Tractors: 4x O's, 70, 73, 100, 102, 125, 147, twin stick 1250, 782,
Attachments: T38 Mott, Danco RD2000, RD300, Amerind Mackassic Chippah, 2x Brinly, IH rear blade, IH rear rake 2x Rear ptos, IH #1 tiller, EZ-Rake Dethatcher, Wind Breaker, power angle plow 54",
Old 12-20-2016, 07:50 PM
Rmowl's Avatar
Rmowl Rmowl is offline
I bought a 450 last year and mounted it to my 782. My IH built 782 didn't have the nuts welded to the frame. Against my better judgement I drilled it out. I only got 1 1/2"-2" lift. Mounted it to my 982 and I get 5" of lift now. Mounting it was so much easier than on the 782. Mine has adjustable lift bars, have it set on the last hole.
-Rick
IH 782
IH 126
CCC 1863
Old 12-20-2016, 10:36 PM
There are supposed to be bolts on the top corner of the blower frame where it mounts to the tractor. Like Rick says, the 782's don't have nuts on the frame. I just used a piece of all-thread and ran it through both sides. Welded the nut on one side so it's like a long bolt. Adjust the rod pretty much all the way out. Your only going to get about 3" maybe unless you 1.) drill more holes in the vertical lift bars, or 2.) lengthen the lift rod by making a new one, or cutting and welding in an extension. Stock set up, they just don't lift very high.
Old 12-21-2016, 06:51 AM
Okay thanks guys. So I have already drilled holes in the straps, one under the slot and 2 others on the bottom and if I had it set up normally it wouldn't lift but if I moved it to the hole under the slot it would lift maybe 2"
