Old 12-08-2016, 03:23 PM
gotmilk gotmilk is offline
Default Steering play
Has anyone ever drilled out the 5/16 hole on the left front spindle and left front steering arm to take up slop... i'm thinking I might drill it to 3/8 and install a Bolt to take up the play... any thoughts????
Old 12-08-2016, 03:47 PM
olds45512 olds45512 is online now
It's supposed to have a roll pin, all the bolt will do is egg shape the hole. I would drill the hole just big enough to make it round again and then buy a roll pin that fits tight.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-08-2016, 06:52 PM
There are taper pins that you can use also from Mc master Carr.They are solid.
I have never used one but it is better than a bolt.
Up to 534 and counting...
Old 12-08-2016, 07:07 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default taper pin
That will work but needs to be drilled with a tapered drill and reamer to make it tight.
Old 12-08-2016, 07:23 PM
Thanks Mike,I thought there were complete kits that they sold?
Old 12-08-2016, 07:25 PM
You could also drill it out to 3/8" and use a 3/8" spiral pin (much better than a bolt).
OR, you could drill it to a metric size just big enough to get rid of the slop and use a metric spiral pin.
Old 12-08-2016, 07:55 PM
Default Kit
I know we don't like to reference to outside sites too much, but this guy here has a solution you can buy. Or, I suppose you could read over his page and make it yourself?
http://www.spaco.org/loose.htm
I think I was linked to this guy from a post on here a few months back.
Old 12-08-2016, 08:42 PM
Default steering play
thanks to all of you, this site is awesome. ill give it some thought, but the taper pin looks looks like the best bet. ill let you know how i make out......
Old 12-08-2016, 08:52 PM
john hall's Avatar
Referencing the other site posted, here is some links to MSC you may find useful. Note that taper pins that are threaded are threaded on the big end for pulling the pin out of a blind hole. If you are going to secure it in place with a bolt, make sure you can drill and tap the pin first!
http://www.mscdirect.com/browse/tn/H...r&sortby=price
http://www.mscdirect.com/browse/tn/F...term=taper+pin
The more I think about this the more I need to go see how many we have that are loose, buggered, welded, have bolts, or are tied on with electric fence wire
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-09-2016, 12:30 AM
I drilled and tapped a hole to except a set screw just below the spiral pin. Tightened it up, and still snug with no slop.
Plus when you have them sunk, dab a little paint on top and no one will ever know.
