Old 12-03-2016, 04:52 PM
Cole_gerhardt Cole_gerhardt is offline
Default 90 Degree tiller gearbox seal numbers?
Hello everyone: Thanks for letting me in on all the great info! I am currently working on my late uncles, now mine 1450 hydro with tiller the 90 degree gearbox. It is leaking out the bottom. It runs smooth and feels good but I would like to rebuild it so it does not sling oil all over. I have read on here, and can't seem to come up with good aftermarket bearing and seal numbers for the gearbox. Also, do I just fill it with 80/90 after the rebuild thanks!
Admin: Corrected spelling and add punctuation so it is readable.
Old 12-05-2016, 09:27 PM
RDBarnard's Avatar
RDBarnard RDBarnard is offline
check out the sponsors at the top of the page, they have what you need.
I use gear oil you only have to fill about 1/3 up.
Old 12-05-2016, 10:38 PM
SLS327 SLS327 is offline
What model tiller are you working on and do you have seal or bearing numbers that you are looking for?
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 12-05-2016, 11:57 PM
No, he says in his post he can't find them.....
Doesn't matter what model, they are all the same. Except for the really old snowthrower boxes... they were slightly different.
See this thread for lubrication info. Tiller box takes the same chit. Don't use straight oil:
http://www.onlycubcadets.net/forum/s...ad.php?t=46853
Old 12-06-2016, 12:49 AM
I took the bearings and seals to my local IBT shop and they set me up with everything I needed I have it all put back together and ready to go thanks!!
Old 12-28-2017, 04:45 PM
edc9336 edc9336 is offline
Can you tell me the bearing and seal numbers for the gear box?
Old 12-28-2017, 04:48 PM
Take it apart. The bearing and seal numbers should be on all the parts. I don't recall all the numbers off the top of my head. Somewhere out in the garage I have a complete set. They cross easy by size too.
