I have a Cub Cadet GT2550 and here in Australia cannot track down any Gator blades for a 50 inch deck , the normal blade is part no 759-04047
Any help in supplying a part no for a Gator blade would be great as a part no might show up elsewhere in my searches Unfortunately postage from the US to Aust is a killer almost more the the price of the blades Regards Oz |
Hope this helps....
I switched from regular blades to gator blades and saw no noticeable difference in cut, I'm not sure I'd spend the money unless your old blades are wore out.
I also switched to gator blades. The only thing I noticed was the clippings are a bit smaller.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Thanks lads for your replies , if there is no noticeable difference I shall save my pennies
The link was great but will stick with the OEM or aftermarket The only Gator blades available in Australia had the star hole and that was NBG for me , I am a round hole kind of bloke when it comes to mowers that is Anyway thanks again Oz |
![]() The gator blades make the clippings smaller for sure and invaluable for making leaves disappear in the fall. Some people use them in the fall only, others all year. They Do a fantastic job on leaves,especially when the leaves are dry, they grind them up so fine, they disappear after a rain.
Anyway all input is greatly appreciated Regards Oz |
Tab |
782 Cub cadet 50 C deck, the discharge chute plugged with an old piece of metal held on with 2, 5/16" bolts.
No chute blockages (lol) 50 incher , and it is a GT2550 purchased in 2013 new but it sounds like olGeorges chute is certainly blocked (lol)
