Old 11-23-2016, 11:20 PM
mattoney mattoney is offline
Default Narrow Frame Hydraulic Add On
Hello all,
I purchased a narrow frame hydraulic lift off eBay, with the intent of cleaning it up, putting in new seals, and putting it on my 104 with a tiller. After getting it here, I realized that at some point, someone has left the cylinder partially extended and exposed to the weather. With as rusty and pitted as it is, it's going to need replaced.
Question is, I cannot seem to find anything on how to tear down the cylinder. I have found where other people talk about welded cylinders, but this one isn't welded. I have found the diagrams on Parts Tree and Cub Cadet parts, but they list no Part Numbers, so I can't even look up pictures of parts and know they go in my cylinder.
I have found a good guide for going through the pump, but just nothing on the cylinder. Can someone point me in the right direction please?
Thanks in advance!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 11-24-2016, 02:09 AM
I don't know where the closest hydraulic shop in your area is, or I'd give you that direction. Your going to need a new rod, so before you spend a bunch of time tearing it apart, I'd find a place that can make you one.
Old 11-24-2016, 09:29 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I'm not sure how they come apart.. I have a friend that has re sealed two for me so I know they do come apart.. I would have to ask him how he got them apart..
But.... I'm with Jon here.. you are going to need a hydraulic shop to make you a new ram (the rusty rod)... those rusty pits will destroy a new seal in short order.. so you may as well hunt a hydraulic shop and let them do the whole job.. that way it should have a warranty..
Those Hyd lifts are fun little projects.. good luck with it!!
Jay
Proud owner of the following:
Old 11-24-2016, 09:31 AM
The only thing that holds it together are the fittings on either end.
Remove them, and it WILL come apart, although it will take a little effort.
If you can get the rod to move at all, clamp one end in a vise and start working it back and forth until you get to the outer extreme end of the stroke.
Keep working it back & forth, to the extreme end until something, one end or the other, starts to pull out.
You can then drive the other end out, whichever one it is, w/a drift. I would suggest a hardwood dowel to avoid possible damage to the inside end of the piston or plug end.
CAUTION: DO NOT CLAMP THE TUBE IN THE VISE! You do not want to distort it.
You should be able to get it rebuilt for around $130 or so w/new rod, hoses w/fittings and seals.
I was unable to get the smaller hose of the two and had to settle for the same size for both.
The shop time was the largest part of the bill.
The rod itself was only about $5
Old 11-24-2016, 10:17 AM
Who sells that rod for $5.00? is it already threaded and the correct length?
Up to 534 and counting...
Old 11-24-2016, 10:26 AM
That's what I wanted to know! Tell us!!
Old 11-24-2016, 10:52 AM
Quote from my receipt from Link Hydraulics in Dubuque, IA.
CR-0500 1/2" chrome rod 8" @.$0.55 $4.40
And no, it's not threaded, that was included in the shop/machine time.
It has to be threaded on each end. It's threaded into the piston end and staked.
The total parts for the rebuild were $28.62+ tx.
Old 11-24-2016, 10:59 AM
How about an address and phone number to them?
Old 11-24-2016, 12:03 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
http://www.linkhydraulic.com
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-24-2016, 12:41 PM
IIRC, that rod is the same on both ends, if your rod isn't rusty all the way down, you may be able to turn it around so the smooth end goes where the seal is.
Tags
cub cadet 104, hydraulic cylinder, hydraulic lift, narrow frame
