Old 11-02-2016, 03:29 PM
adamo adamo is offline
Default 129 help/ part question.
Pretty sure I screwed up and put this on wrong. Is it suppose to be the other way? I cannot find a diagram online for it. If so, how can this pin come all the way out. Sledgehammer is not working.
Old 11-02-2016, 04:00 PM
john hall's Avatar
Why can't you just use a pin punch and drive it out from the other side? I would open my vise slightly more than the size of the pin, lay the shaft crossways with the pin in the opening and tap it out--this way the vise would serve as a v-block to give adequate support.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-02-2016, 06:27 PM
Heat!!!
Old 11-02-2016, 07:01 PM
Well, if you assembled it wrong, sounds like you just drive the pin in...... should come out.
Old 11-02-2016, 07:04 PM
athomas's Avatar
athomas athomas is offline
Short end of drive hub faces engine and long end with slot faces trans. Pin punch should drive it out easily when supported as mentioned above , good luck
Old 11-02-2016, 07:26 PM
Default Update!
Thank you for the vise idea. After about 2 hours, the pin came out. So now I'm stuck again. What is the method for getting this thing in? The pictures are as close as I can seem to get it. Short of banging the crap out of it, how does it go in? I just don't think I should really need a crow bar to leverage this thing in.
Old 11-02-2016, 07:31 PM
cubs-n-bxrs's Avatar
Unbolt the engine and slide it forward a tad. Should fall right into place.
Old 11-02-2016, 07:34 PM
Holy cow. How difficult is that?
Old 11-02-2016, 07:59 PM
4 bolts should take maybe 15 mins. That allows for a cold one or 2.
Old 11-02-2016, 08:02 PM
Ok I'll give it a go. Anything I need to watch for? Never removed an engine before. Because it something could go wrong, it will to me and this cub -_-
