hello everyone,
I recently picked up a cub 3185 with 600 hours or so, so far its been a great tractor compared to my 1641 that isn't getting much usage these days. Anyhow i'm going to pick up a snowblower tomorrow , and realized I only have one lift handle. I cant seem to find what is needed for the second lift handle. I've tried a google search with no good results. Does anyone have a picture of how the second valve is plumbed in. The guy i'm buying the blower from is parting out his tractor which has two lift handles, so I can get all the parts just wanted a good idea before I get there on what I need to strip off. |
You don't need a two spool valve for a snowblower, the lift that lifts the deck will also lift the blower.
Im referring to the 3185 not the 1641 , im pretty sure I need a second spool, considering the blower has its own lift cylinder
yes need a second spool, hoses, cylinder, mine has the quick attach optrion on the front, second spool mounts under the existing and the new handle will be right behind the existing, check my other posts for pic
I purchased the blower, along with with hydraulics , just took both his valves since they were mated together, I guess that is where my confusion was, I didn't realize that the valves mated together and wondered how they could fit so closely if a line joined them.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
I kept my old one, not really sure why I would need 3 but I like the thought of it.
And you can cut the fender pan and 3 more to the right side to make it an H6.
You been reading my mind? Get out of my head! Lol
Look closely at the rear fender
