Old 10-29-2016, 02:32 PM
Geoff's Avatar
Geoff Geoff is offline
Default Hydraulic fluid
Happy weekend everyone .
I am going to change the hydraulic fluid in my 1980- 682 ( SN is 683439 ). If I were to pull the cover off the rear end, would I find a gasket that would need replaced or ..... ?
"One way to make sure crime doesn't pay would be to let the government run it."
-Ronald Reagan
Old 10-29-2016, 02:55 PM
Gasket IH-350837-R3 is available from any Cub Cadet or Case/IH Dealer, as well as, numerous places online.
Old 10-29-2016, 03:00 PM
Geoff's Avatar
Thank you !!!
Should those rear bolts be torqued at a certain spec and is a gasket sealer advised ?
-Ronald Reagan
Old 10-29-2016, 05:44 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I don't use a paper gasket on any rear cover. Grey or black RTV. Just a 1/8" bead. Torque 20- 30 ft lbs.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-30-2016, 12:03 AM
I use RTV also, but I don't torque the bolts. Travis' torque spec is correct if you feel the need to torque them.
