Old 10-17-2016, 09:58 PM
taylorjm taylorjm is offline
Default What's a Haban?
Ok, I've searched though a couple hundred posts, and looked through the library, but can't find the answer to a stupid question. What's a Haban deck? I have a 60" deck on a 2182 model says 60" Deck, 372190 and either 60C or 600.
Old 10-17-2016, 10:01 PM
Terry C's Avatar
Terry C Terry C is offline
There is a Haban deck in the pic.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-17-2016, 10:02 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
That's a Haban! It is the name of a different company that manufactured implements. They also made snow blades for Cubs. Maybe even more but my brain is otherwise occupied tonight.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-17-2016, 10:06 PM
So did Cub make the Haban decks? Mine has a CC label on it.
Old 10-17-2016, 10:10 PM
Shrewcub's Avatar
No. It looks like there is a tag underneath that too, Cub did sell them tho.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 10-17-2016, 10:13 PM
Boy it sure does look like a tag underneath the riveted CC label doesn't it... I never noticed before, but never looked that close either.
Old 10-17-2016, 10:15 PM
Dirty Steve's Avatar
That white deck is a 374 Haban deck. There are also 325 Haban decks. Here are some pictures. Similar in structure but the yellow 325 deck has different caster wheel setups. The outer pulley covers are very different also. I don't have any pictures to share of the pulley covers. The 2 early serial number break 2182's came with the white 374 deck. The 3rd serial number break tractors had the yellow 325 decks.
Old 10-17-2016, 10:20 PM
Thanks!!! Next, I'm trying to find out if they make mulching blades for them. I have a plate that goes over the hole for the clippings, but all they do it clump with the current blades. I will look and see what's on them when I get there again. I know the PO also left a set of blades that look like it has sharp teeth cut into the first 5" from the ends of the blades. I'll have to get pictures of those as well.
Old 10-17-2016, 10:29 PM
Sounds like the other blades you have described are Gator blades, which are mulching blades.
Old 10-17-2016, 10:34 PM
Haban was a manufacturing company in Racine WI, that made implement for various Garden Tractor Manufacturers to include IH. They made a variety of implements to include: mower decks, sickle bar mowers, front dozer blades, snow throwers, and snow blowers, to mention a few.
