Old 10-15-2016, 11:41 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default Nasty, Dirty 1864
Well it started out with adjusting the brakes so that they would hold when you lock the pedal. Then I thought that while I was working on the new tractor a little that I would go ahead and remove that throttle stop screw so that well, you know, more HP ??? Should have left well enough alone, but I paid the price. Dropped the screw down in the blower housing and could not reach it with a magnet, so not that I had time to do it today, I had to pull the motor out to get to the screw, but what I found was a TON of muck and dirt and a leaky seal. Could not find a seal anywhere local so I had to order it.
See link to album below for pics
http://www.onlycubcadets.net/forum/a...p?albumid=1094
Can't say enough about taking the time to blow out those motors periodically. That dirt really builds up bad and can cause a lot of problems that will cost you money and unplanned downtime when you don't want and for something that you could have prevented, to some degree anyway.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 10-16-2016, 09:17 AM
bugeye bugeye is offline
I use a leaf blower after every use on my 1864. I also use a tube with the air compressor trying every opening I can find to blow out the cylinders and blower housing. I have removed the engine a few times in the last 20 years. The blower area is still covered in dirt. Removal is again due. Sounds like a winter project.
Old 10-16-2016, 10:16 AM
BIGMOZEKE's Avatar
Just got this tractor so since I have the motor out and the blower housing off, I am going to put some access holes in there to allow me to blow it out occasionally with compressed air. Will also put some holes in the bottom so that everything can blow out.
Will post some pics for the new mod.
Joe
1200 Puller[/U][/B]
1864
Old 10-16-2016, 10:36 AM
If you go to lowes they sell stainless plugs, buy the plugs in the size you want and then drill the holes. The plugs will keep you from losing air flow over the cylinders but still allow access to blow it out.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-16-2016, 10:37 AM
Joe
The newer CH's have removable panels on the blower housing, here is a pic.
Old 10-16-2016, 10:40 AM
BIGMOZEKE's Avatar
That is a GREAT solution that came TOO FREAKING late for Kohler!!!!
Did you give them that idea?
That is also much better than what I was going to do Sam.
Will try to come up with some material and a good reliable way to attach them to the housing without the risk of the screws falling down into no mans land...........again.
Some large conduit blank plugs may work as well, I'll have to look and see what sizes I have and how far they would stick inside the housing.
Definitely something that should be done to all command motors when you have them out doing the maintenance or any repairs.
Joe
1200 Puller[/U][/B]
1864
Old 10-16-2016, 11:51 AM
Dirty Steve's Avatar
Yup, quite the mess. Good work keeping that one going!
Old 10-16-2016, 11:58 AM
Keep up the good work, Joe!
Old 10-16-2016, 09:27 PM
BIGMOZEKE's Avatar
Default Installed Cleaning Ports on the Command
Couldn't resist doing this while I am waiting on a crank seal.
Made a template and cut out the opening in the housing with one of those sonic tools, worked great.
Going to put blank conduit plugs in the bottom tomorrow.
Joe
1200 Puller[/U][/B]
1864
Old 10-17-2016, 07:45 AM
Looks good. Maybe a product for sale.
Please post a picture of the bottom plug and with the fan housing installed. I'm interested in the access to the cylinder and head.
