Old 10-03-2016, 02:53 AM
Default New DIY Landplane For My IH
I never really had an attachment that would use the power of my 584 IH,,,
mostly because CATII attachments get REAL expensive.
The box blade, and even a 7 foot rear blade never taxed the 584's HP.
Well,, one night I got hooked watching YouTube videos of LP's,,, they do an amazing job.
I looked at my material stockpile, and decided I had most of what I needed.
I remembered the local CAT dealer had a graveyard of used and takeoff parts they sell cheap.
I went down there, and,,, sure enough, they had the four 7 foot grader blades I was hoping for.
Two are 5/8" thick, two are 3/4" thick, all are 8" wide, and 7 feet long.
The bolts that hold them on are even massive,,
The bolt on the right is a 3/8" bolt, for comparison.
Then, after a lot of sawing, some drilling,,,
finally, I got to the fun part, the welding.
About a week ago, I spent 3 hours getting the front blade assembly into the frame.
The blade assembly weighs over 325 pounds,, it was a monster to position and weld, because of the 15 degree angle.
Purely by coincidence,,, the night after I finished the welding of the front blade, we received 5 inches of rain.
My 1400 foot driveway was obliterated.
No time for testing, and paint, the landplane had to go to work.
Old 10-03-2016, 02:54 AM
Here is a pic of that section of the driveway after four passes of the LP, two up, and two down.
The LP earned its keep on its first outing,, the 584 finally has an attachment that will make the engine pull.
After grading, I rolled the driveway with my ~300 pound roller.
After seeing the results, my SIL is nagging me to build a miniture version, so he can use it behind the 2284 CC,,,
Old 10-03-2016, 04:54 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Incredible build...amazing results!
Queen Of The Quietlines!
Old 10-03-2016, 05:58 AM
twoton twoton is offline
Nice job!
Now you just need one of these to go with it...
Old 10-03-2016, 06:14 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
I really like that....nice job and photos, thanks for sharing.
Old 10-03-2016, 07:20 AM
John
That came out sweet! You have too many cool tools.
Old 10-03-2016, 11:10 AM
bugeye bugeye is offline
Quite professional build. Works beautifully.
Old 10-03-2016, 12:01 PM
Nice work, John! Glad it did a great job for you!
Old 10-03-2016, 05:27 PM
John
What also impresses me about Mr. Plans also is his ability to both engineer and fabricate, as sometimes the two don't go hand in hand but in his case he's gifted to perform both. There are some guys that are amazing engineers but don't turn the wrench or sympathize for those of us that do. It's awesome when they also can work on what they created.
You new guys should look at his site and see what he's done. Impressive to say the least. Not trying to put him over for any benefit but I'm a fan of his work.
https://www.cadplans.com/
Old 10-04-2016, 12:51 AM
Good idea John. To bad you weren't a couple hundred miles closer. We have tons of used cutting edges sitting here waiting for someone with this idea.
