Old 09-22-2016, 07:53 AM
amflyer amflyer is offline
Talking Bolt Length
Just scored a pair of IH wheel weights yesterday. I plan on putting them on our 149 for winter duty. These can be mounted on the inside of the wheel. Can some one tell me the length of bolt I need to use to install these on my wheels. I know that washers should be used on the one side. Also if there are any recomendations when mounting these that would be appreciated as well.
Old 09-22-2016, 09:17 AM
You can only put them on the inside if it has an internal brake.
Take the wheel off, measure to see how long of bolt you need, buy the bolt, bolt them on.
If going on the outside, procedure is the same, only you don't have to remove the wheel.
Not sure there is anything else to say.... It's about like asking for help installing a tire.
Old 09-22-2016, 10:31 AM
If it were like that I would not be asking? The info on the brakes is good, just thought someone would already have that measurement without making me sound like I was asking a dumb question. Am disabled and would have just liked to go buy the right length without issue. The weights are rather heavy and measuring them is a little tough.
Old 09-22-2016, 10:46 AM
I just went out back and measured and it looks like you need a 4 1/2" bolt but you will probably have to settle for 5".
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-22-2016, 10:55 AM
Smile
Thank you sir for your response, this makes this a lot easier for me and I do really appreciate it!
