Old 09-18-2016, 07:46 AM
bugzilla46310 bugzilla46310 is offline
Default 782 hitch and watering/spray trailer
Needed to upgrade the original hitch on my 782. I use it mainly for leaf vacuuming and hauling firewood and the original was getting worn. Been tripping over this old bumper mounted car hitch in my barn for some time and decided to utilize it on my 782. It is bolted to the frame and original hitch. I welded some cross bracing. Mounted the 12 volt plug on the hitch. The ball is stored on the hitch if I need to tow my log splitter. Only problem is on rare occasion, I could use some front ballast. Also a few pictures so a watering cart I built. It has a short hose for watering from the driver seat, a spigot for filling buckets, and nozzles for spraying the lawn. The drum is a SS 55 gallon drum I picked up for $5.
Having problems uploading more than one picture. Will post more of the cart on future posts
Old 09-18-2016, 07:51 AM
twoton twoton is offline
Hitch looks rugged! Nice job.
Old 09-18-2016, 07:58 AM
The watering cart
Old 09-18-2016, 08:02 AM
Valving panel on spray cart. You can valve in the watering hose or lawn spray nozzles. There is a spigot teed into the drum outlet so you can fill a bucket without using the pump.
Old 09-18-2016, 09:02 AM
That's quite the rig!
