Old 09-05-2016, 07:10 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Sediment Bowl Cub 149
What is the purpose of the sediment bowl and how does it work. Getting ready to clean mine and install it on my 149 that I am giving a face lift. The wire screen looked clean, but the bowl had a lot of crud in it. My fuel tank looked clean and no rust inside. Thanks and have a great day.
Bob
Old 09-05-2016, 07:13 PM
Sediment bowl is early filter. Junk in fuel collects in the bottom of see through bowl and fuel then filters out through a screen to carb.
Old 09-05-2016, 07:26 PM
^^^Yep!
Plus, it lets water settle out. Filters don't.
Old 09-05-2016, 08:24 PM
A 149 did not come with that type of setup.But is is a good idea like Big Johnathan mentioned,not sure if there is room for one on a 149....
Up to 530 and counting...
Old 09-05-2016, 09:14 PM
I was thinking that too LP. Should have a straight t valve shut off on the bottom of the tank with a screen up inside of the tank right?
Old 09-05-2016, 09:24 PM
right ,ten characters
Old 09-06-2016, 09:46 AM
Mr Bob's Avatar
Thanks for the info. The sediment bowl was on it when I bought the tractor. It seemed like the bowl was never full of fuel, and I can't vision how it gets back to the fuel line to the carb. Maybe it was full and I am remembering incorrectly. Thanks again and have a great day.
Bob
Old 09-06-2016, 09:51 AM
ambrola's Avatar
ambrola ambrola is offline
I started my O a couple weeks ago, and went back later that day and it wouldn't start? After checking that I had fire at the plug, I knew it was a fuel issue. Ordered a new sediment bowl, and she started right up. The old one was trashed. The screen was completely clogged with 50 years of gunk.
Old 09-06-2016, 10:20 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
I just ordered an original with a valve shut off, the previous owner had removed it and put in an inline filter with rubber fuel lines,
I plan to hard pipe it back to the Carb. I like the bowl types because they will trap water along with crude.
