Howdy all,
So it has been a long time since I have been on here. I have a few questions about the hydro on my cub cadet 1650. It has developed a leak on the hydro pump by the shaft that is coming out of the side. opposite of the speed controls. I have attached pictures. It started when I was going high speed for about 15-20 minuets. I was pulling a small trailer with my two buys in in. Does anyone know if I have to split the pump open or can I just replace the seal with minimal disassembly. I looked for a thread on this but I was unable to find exactly what I was looking for. I was also wondering if that seal is gone what other seals should I do while I'm in their. My last question has to do with the tag on the pump. How would I identify this pump and what do all of the numbers mean. |
The red circle is where the leak is coming from. So I have to split the case open in order to replace it. BOOOOOOOO. Are their any links on how to do this.
Looking at this picture you apparently have more to take care of unless my eyes trick me...
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
You can replace the leaking seal without splitting the pump. You also should rebuild the trunnion area as OldSkull mentioned. That said as soon as you fix one leak others will follow. If it's leaking on one side it won't be long till it leaks on the other side. Life sucks, your tractor is old and it wants new seals and gaskets.
Replace the seal that is leaking, it is the easy one, no disassembly of the hydro needed.
If it ain't broke, don't fix it. ![]() Do repair your trunnion, and, it would be nice if you had 2 release valves that were automatic, not just one. ![]() |
That is great news to hear Yahoo. I am in the process of rebuild my relief valves and I was going to get new springs and get that fixed. I am also going to replace the fan and do a good cleaning. Thank you very much for the input. Ill be sure to put an update when I'm done.
![]() Quote:
![]() Quote:
Post 1, picture 1 shows a nipple er button ![]() da udder fotos no nipples er buttons Me thinks somebody tried to confuse me. Sometimes I don't know if I'm cratchin' me watch or winding me arse ![]() |
![]() Quote:
![]() You see nipple where there is none, maybe your level of testosterone is getting a bit high! No more blue pill for you! ![]()
Yep,
blue pills I use em, except they are Naproxen ![]() But seriously, do you not see the manual button in the pix with the identification tag? Something don't look right there? ![]() |
