Old 09-03-2016, 08:53 AM
ohioron ohioron is offline
Default Cub Cadet 1250 coil
replacing a coil on a 1250 with Kohler engine in an attempt to get it to run. need to know if I buy (NAPA) coil with an internal resistor or is there a rresistor on the engine. could also use a source for an electrical diagram for the Kohler engine that might show a resistor. thanks, ron
Old 09-03-2016, 09:08 AM
No external resistor.
Takes a 3.5-4 ohm coil. IT DOES MATTER. Make sure you buy the correct coil.
Old 09-03-2016, 09:20 AM
mortten mortten is offline
At NAPA I recommend an IC64 or an IC64SB coil. Resistance is 3.8 to 4.2 ohms. The IC64SB will likely be less expensive as it is their consumer line and probably imported. The IC64 will be their top of the line.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 09-03-2016, 10:05 AM
Default 1250 coil replacement
new at this and don't see how to thank the guys for suggestions for a coil. so will just say thank you here and see if it works, ron
Old 09-03-2016, 10:07 AM
Your welcome.
Old 09-03-2016, 01:22 PM
They may also offer up a 7-01634 in their small engine parts line. It comes from Prime Line. Probably a repackaged something.
Doug
QA-36A
42" blade
Old 09-03-2016, 02:47 PM
thanks for the suggestion. will follow up. ron
Old 09-03-2016, 07:12 PM
A lot us guys use this coil with very good results....
Old 09-03-2016, 09:40 PM
was able to get a IC64 from napa and it started right up.thanks for all the helps. I had no idea what to get and you guys solved it for me. they didn't have the IC 64 SB which they said was the cheater model by $4. great site, my first time using it. ron
Old 10-01-2018, 12:56 PM
binderreb binderreb is offline
Default Resurrecting a thread (not a coil)
Bringing this one back from a bit of sleep. NAPA says that the IC64 has been "superseded" by the IC14 - might I get a second on that one?
Thanks!
Ron in NC
