Old 08-28-2016, 03:01 PM
Doc Brown Doc Brown is offline
Default New member and new 127
Hi All
I'm a new member and would like to say hello from Minnesota first off.
I'm also new to IH cub cadets as I just bought a really nice shape 127. It came with original service manual and I bought an original operators manual off feebay also. There were some things that needed fixing which I got fixed. I'm in need of a new driveshaft as the pin hole is basically worn oblong as is the coupler pulley but it still works for now.
I fixed everything I thought to get the mower deck running and I got the mule drive belt put on and went to start it and then she wouldn't hardly turn over. Turns out the pto clutch is stuck and the starter generator can't overcome the added drag from turning the deck pulleys. Looks like I need a pto clutch rebuild kit. I've read a bunch on how to do it and it seems fairly straightforward.
Is there a master rebuild kit that includes the pressure plate and both buttons? The button on the tractor side is worn to a nub and needs replacement. Also, has anyone tried an electric clutch like they sell on eBay? Seems the manual pto clutch system on this thing is a little crude.
Thanks
Doc
Old 08-28-2016, 05:01 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Welcome to the fray known as OCC !!
The 127 is my "favorite".
Although maybe "crude" the pto is effective, long lasting and easily rebuilt for cheap.
Get with "Jeff in PA" member here for a brass tractor side pto button.
Almost all of the website sponsors also handle the rebuild kit.
Old 08-28-2016, 05:25 PM
mortten mortten is offline
The engine is not drilled and threaded to except an electric clutch. The master kit will have a disc and springs. The PTO button and the wear button on the lever are separate items and available form sponsors above and other outlets. Consider a brass wear button from Jeff in PA. Better than the finer one.
Old 08-28-2016, 10:37 PM
Welcome to OCC! Congrats on your 127!
Old 08-28-2016, 10:43 PM
What's up Doc? The 127 is a fabulous cub cadet with plenty of power and just the right size. The hood on the 127 is one of my favorites that IH put on a cub, too. Hope you enjoy it.
Certainly looking forward to seeing pictures of your 127. Also, you might consider checking the tension on your belt for your mule drive.....perhaps it is too tight, causing more unnecessary drag.
Old 08-28-2016, 11:29 PM
SLS327 SLS327 is offline
Welcome to OCC! I have a 127 too, and use every week. PTO and deck spindles was the first repairs on my tractor. Good luck and post up some pictures of that new machine!
Chances are there is not enough button left on the tractor side to fully disengage the clutch, and the PO had it set too close when engaged.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 08-28-2016, 11:53 PM
Wink
Thanks all for the welcome and advice. I can't get over how incredibly over built these vintage marvels are or how cheaply made current machines are. It's amazing the contrast.
Boy I wasn't expecting the weight of this machine especially the big cast iron grill in front. Yikes. What I wasn't expecting to see is pinholes in the mower deck! That deck has pretty thick steel but I noticed in a few spots it's rusted through. I am thinking about scraping off the gunk on the underside and welding in some 1/8" plate in spots.
I'll post some pics later as I think they need to be resized to post them. It feels good to own a small piece of Americana in lawn tractor form.
Old 08-29-2016, 12:01 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
I'm guessing you, Doc Brown, love back to the future...?
I do
1- 1200 in pieces
1- 1864 in pieces
Old 08-29-2016, 12:38 AM
Welcome to the madness.
Looking forward to the pictures of your 127.
"It feels good to own a small piece of Americana in lawn tractor form."
It does, but don't mistake these Garden Tractors as lawn tractors, cause there is no comparison between the two.
Old 08-29-2016, 05:40 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Welcome.
As mentioned Jeff in PA can get you a brass PTO button. He can also make you a driveshaft, so you'll have one stop convienence.
I'm in the middle of rebuilding my PTO for my 149 right now. Lots of resources here, it's fairly straight forward, and the parts, bearing and all are less than 1/2 the cost of an electric PTO.
Good luck with the repairs, and show us some pics
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
