Hello all,
I'm new to this forum and to cub cadets. My father in law gave me a model 2146 with 1200 hours on it. He bought it new in 2000. I've been using it for two months now and making repairs as I go. I had to replace a tie rod first. Then added orings to the hydro dip stick to stop the oil from leaking out. I'm mowing a hillside. Now I've got an oil leak under the oil pump cover so I need an oring replaced. The bearing is out of the pto clutch so I have a new clutch on order. Other than these things it seems to be ok. Until the next thing breaks. Now I realize there are good models to own and there are models that are not so good. My question is, is this model worth keeping and fixing or will it just continue to give me problems? |
The first cub cadet I had was an AGS 2130. It mowed very nice but had similar problems you are having. I kept going older and older and liked them better the older they got. I really like narrow frames and 82 series, my primary mower is a 982 now for the time being.
That is just my opinion. If it were me and I were in your predicament I would fix that baby up, sell it and get an old IH cub. I have run the crap out of a 124 and has required virtually zero maintenance and does an outstanding job cutting grass or plowing a garden
-Rick IH 782 IH 126 CCC 1863 |
Welcome to OCC!
I'm sure you will get more good opinions from members here
Sounds like you put some money in the ol girl. Up to you, but id probably finish out the year, clean it up and try selling it next spring if you have the storage space. Its my general observation that a 782 with kt17 twin, 1811, 1864 are probably the most sought after machines if your wanting a machine that has good power and hydraulic capabilities.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
Thank you for the responses. I gather from your post that the 2000 series is not the best out there. I think I'll continue to keep it running and use it for now. I'll also watch for and try to learn something about the other mowers you mention. Thanks again.
