Old 08-12-2016, 04:21 PM
ambrola's Avatar
ambrola ambrola is offline
Default Mower Decks
Is there somewhere you can get the numbers to the decks on the older Cubs? I found this one in town next to me. Will it fit my 124?
Old 08-12-2016, 04:22 PM
ambrola's Avatar
Old 08-12-2016, 04:58 PM
Can you post an underneath side photo? I think it's the first series of the 48" 3-spindle deck. To find it on CC website, go to the Attachments section for your 124 and select 48" 3 spindle deck. Should be part 1 (1963-1968). Yes, it will work on your 124 as long as you have the correct subframe. That deck is setup for the pin-on style, not the quick attach style that would have originally come on your 124.
Old 08-12-2016, 10:46 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
It looks homemade. The deck shell looks fabricated.
Queen Of The Quietlines!
Old 08-13-2016, 09:05 AM
Ronnie, he is a member on here.(Dave1953) I've purchased some nice stuff from him and he is a great guy. Give him a call, he won't do you wrong.
Old 08-13-2016, 09:30 AM
ambrola's Avatar
Thanks Oak,
I see it's missing the guards? And I still haven't found the thread that puts the decks with the tractors?
Old 08-13-2016, 10:07 AM
Belt tensioner looks funky.
Old 08-13-2016, 11:26 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I agree.
The corners are sharper than factory and although hard to see, likely all welded corners versus bent corners.
Old 08-13-2016, 01:11 PM
budscub's Avatar
budscub budscub is offline
Originally Posted by DoubleO7 View Post
I agree.
Yes I m thinking the same thing, if you look along the front where the deck gets deeper, along those rust lines looks like maybe the upwards offset was made using a piece of angle iron. Where the rust lines lay seem to be a seam.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
