Old 05-19-2010, 01:34 PM
bigdaddyjak bigdaddyjak is offline
Default 123 hydro problem
went to pick up my other 123, very little to no forward movement, reverse works just fine, slow or fast.it looks to be in adjustment, what could be the problem??? The shifter and linkage move forward and back freely and as they should, just no forward movement? Thanks In advance!
To much to list!
Old 05-19-2010, 01:45 PM
Switch the relief valves and see if the problem moves to reverse. If not, you probably have a clogged hydro filter, in which case you'll need to change the Hytran and filter.
Old 05-19-2010, 01:51 PM
this must be the reason they got rid of this, as the handle to push the relief valves is gone, I think I can get to them anyway .Thanks Matt, will try. Set the points and it ran pretty good, as it has been sitting outside uncovered for better than a yr. hopefully, the hydro problem is not to significant, I will mess with it this evening . Again Thanks!
To much to list!
Old 05-19-2010, 05:08 PM
After looking at it a bit more it seems as if 1 of the relief valves is stuck !
To much to list!
Old 05-20-2010, 02:38 PM
relief valve was stuck , freed up and working good !! Thanks Matt !! Now the hydro lift works great, except for leaking like a siv out of the shaft end where the sheave is on the pump! what is the best way to go about this? is there a rebuild kit, or take it and have it done? Thanks !
To much to list!
