Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 07-22-2016, 01:59 PM
corporalk corporalk is offline
Default Cub Cadet 1650 with 44" mower
What's it worth in your opinion if it's running and fully operational as seller says. The owner was using the tractor to push cars into his service bay.
1977 Cub Cadet 1650 with 16HP Kohler and 44" mower.
Link to more pictures here;
https://www.dropbox.com/sh/gbzp3if4k...RkLyWuIGa?dl=0
Old 07-22-2016, 02:21 PM
Terry C's Avatar
Terry C Terry C is offline
$552.45.
But seriously 6-7 hundred tops if it runs good
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-22-2016, 02:32 PM
Thanks, looking into this for my son to cut the lawn and have a little fun pulling at local events. I know the hydro is not the desired tranny for pulling, but the owner has been pushing cars so I'm hoping it will perform okay.
Old 07-26-2016, 11:42 AM
Default 1977 CC 1650 with 44" mowing deck
Hey, got the 1977 CC 1650 with 44" mowing deck for $400. It runs and the kids are having fun. Mowing deck is fully operational and looks to be in great condition. The engine needs a little TLC; head gasket, muffler, isomounts, lower grille screen and air filter. Let me know if anyone out there has the parts needed for sale or willing to send to a 13 year old kid.
Big push bumper has since been removed.
https://www.dropbox.com/s/3w02ro1048...l1600.jpg?dl=0
Old 07-26-2016, 02:33 PM
Terry C's Avatar
Congrats! It looks pretty nice
Terry
3225
Old 07-26-2016, 08:31 PM
Congrats on the 1650.
Old 07-28-2016, 01:13 PM
Thanks! Turns out it is a 1979 CC 1650, both the tractor chassis and Kohler engine records indicate both were made in 1979, the chassis was in July of '79.
I discovered the engine moves a little when I push on it, this can't be good. I know the isomounts need to be replaced, but it appears the engine is moving independent of the two rails with the isomounts installed. I do not know if a little engine movement is normal and intended. Can you clear this up for me?
Old 07-28-2016, 05:57 PM
to bolts have most likely loosened or fallen out where the rails bolt to the oil pan, its a pretty common issue and most people solve it by replacing the aluminum oil pan with a cast iron one. there's also a mod where you connect the two rails together by welding a piece of steel between them.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-28-2016, 11:06 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
^^^^^x2 and then you get to decide what mounts your using!!
Congratz on the 1650, nice looking tractor
1- 1200 in pieces
1- 1864 in pieces
Old 07-30-2016, 07:53 AM
Dirty Steve's Avatar
That's a ice looking tractor. Congrats!
