Old 07-20-2016, 12:54 AM
GERKS 149 GERKS 149 is offline
Default 129 moves sporadically
I bought this 129 and I am having problems with it moving forward and backwards. What it does is move sometimes and not others. To get it to move, I have to move the handle forward and back all the way and pretty quickly then it seems to go with good force. Tonight I popped off the tunnel cover and expected to see the linkage not moving or something, but it moves perfectly with no binding or anything. The handle moves with no real tension like my others. Don't think it is the 2 valves because it is both a forward and reverse problem.
I purchased it for the rear agg tires and expected to sell it. To my surprise the 12hp engine is perfect running with no smoke and the fender bodywork is real nice. Any suggestions??
Old 07-20-2016, 01:11 AM
Standard answer we give about 100 times a year: Did you change the fluid and filter on the rear? Or at least check it?? If you didn't, start with that.
Old 07-20-2016, 01:14 AM
I did check the fluid level and all good. Not sure how to check the filter unless I replace it. Also no leaks of any fluids!!
Old 07-20-2016, 05:03 AM
It will probably take more effort than this but (just because it's cheap and easy) if the relief valves are the manual style, try grabbing the little tits on each one with some pliers and see if you can pull them up, maybe twist them when pulling up.
If that doesn't do it, you're back to changing the oil and filter...
Just think, when you get this one working, you'll be looking for another pair of tires.
Old 07-20-2016, 08:25 AM
dale c. dale c. is offline
the trunion springs might have fallen out due to worn out parts, look back under the fenders and you'll be able to see it
I would change the fluid and filter before going any further.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-20-2016, 08:45 AM
Ditto. Filter probably weighing in at just over 5 lbs
Old 07-20-2016, 09:14 AM
You aren't going to sell this 129 once you get it fixed, you realize that already.....don't you? I'm with the rest, I believe it is your filter but you may still want to spray those relief valves with some PB Blaster and as Mark pointed out, make sure they are fully actuating.
Old 07-21-2016, 03:39 PM
Great points to check. I have some generic IH fluid and a filter in my basement. But I hate to say that I have to sell it. There isn't enough room to keep them all as much as I want to!! would like to keep it together rather than sell it off piecemeal. Just hope to get enough back for it
Old 07-21-2016, 03:52 PM
Make sure you use a Cub, NAPA or WIX filter. We have recently seen guys that have used engine oil filters and they don't flow so the tractors a no go. NAPA # is 1410 and WIX is 51410, don't remember the Cub # off the top of my head.
