Old 05-18-2010, 07:49 PM
Fishman1978 Fishman1978 is offline
Default Large wheel weights!!
Picked these up weekend before last, they weigh 175 lbs apiece. I'm a little skeptical about mounting them. They do not fit all the way against the lugs, and not sure if they will bend my rims. What do you think?
Old 05-18-2010, 07:56 PM
Wow, 175 lbs. each???? That is probably too much wt. for that transmission. What are you mounting them on? Most wheel weights are between 25-50 lbs. each. Who did you buy them off of, Arnold? What are they made of?
Old 05-18-2010, 08:05 PM
If you used all 4 bolts they'd probably be alright. I wouldn't worry about 175#/wheel...most CCs with loaders have a lot more than that on the rear.
Old 05-18-2010, 08:24 PM
CBH's Avatar
CBH CBH is offline
Wow! What were those used on before you got them?
Old 05-18-2010, 09:22 PM
Hey Fishman1978
You are probably right. You better just let me come and get them, that way you don't take a chance on tearing anything up :biggrin2.gif: I will try them on mine and let you know how it goes
But seriously those are beautiful. I have never seen a single set of wheel weights that big.
Old 05-18-2010, 09:29 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
I am thinking any spinning issues will be resolved with those on...WOW!!!!
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 05-18-2010, 09:43 PM
murphycc
Guest
Posts: n/a
I'd only want to put those on once......that's all I got to say.....
Scott
Old 05-18-2010, 09:52 PM
You can never have too much weight,
too much money,
too big of a barn/shed EVER!
Old 05-18-2010, 10:50 PM
Now that's what I call weight!
Old 05-19-2010, 05:40 AM
Thanks all for the advice and offer to try them out for me!:biggrin2.gif: Bought them off of a guy in southern IL. He stated he had them on a 1450 for a couple of years and had no problems with them. They are cast iron, and have no hole through them to access the lugs. The mount holes were full of dirt and were pretty rusty, so I cleaned them out, soaked them in Kroil, and ran a tap through them.
Now have to decide which tractor to mount them on:biggrin2.gif:
Also picked up a 1650, and 2 782's, an IH and a CC. The IH has a KT17 that is locked up and the cc was a 782D that he pulled the D out of and repowered with a M18S.
All 3 tractors have issues, got the 1650 running after a carb rebuild and timing set, but has a little rod knock. It is in the repair process now.
I don't know much about the Kohler twins, so the 782's are on hold for a little while.
Pic of the 1650 with K341 on hoist. The iso mounts were so worn that the engine mount frames wore into the cross brace for the front axle mount,
Will try to get some pics of the 782's up later this week, will be away for the day, have to take the wife for a medical procedure.
