Old 07-01-2016, 09:22 PM
Rainman4820 Rainman4820 is offline
Default Where to Start on a 1641
Hello all, I just acquired a 1641 that has been sitting for about 6 months. Cranks and starts with starting fluid but quickly dies. I am going to start with the obvious fuel issue and I have been searching threads for a comprehensive start to finish guide of areas to check but came up empty. Based on what I have read here, I am going to change the fuel filter, check the solenoid (which apparently can be altered or bypassed), try to clean the main jet before I remove the carb and change out the gas in the tank. Other thoughts on where I should check?
Old 07-01-2016, 10:18 PM
Terry C's Avatar
Terry C Terry C is offline
I'm not going to tell you what to do but when I get one that I don't
know the history of I remove everything that has to do with the fuel
system and clean it. Remove carb and clean well, change all fluids and
filters. Remove engine cooling tins and make sure there is no mice nests and
debris.
I'm not one for leaving things to chance.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-01-2016, 10:27 PM
I would get it running first with a remote tank directly connected to the fuel pump to see how it runs,IE. smoke,knocks ect ect,then go the route terry said.
Up to 530 and counting...
Old 07-02-2016, 05:57 AM
Dirty Steve's Avatar
What he said. This method is quickest way to see what you got there. Hope it turns out in your favor. They are nice tractors.
Old 07-02-2016, 09:35 PM
Tankman's Avatar
Tankman Tankman is offline
All the above! Perhaps fuel lines also!
I did all the above then changed hydro and engine oil and the proper filters.
Grease all. New deck belt. mule drive belt both Huskee Kevlar, on the rack at TSC.
Sam and Lew are the gurus! Ask away.
This Cub, our only Cub, is now our go to worker. Good luck with yours!
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 07-09-2016, 12:04 PM
Default Fuel System Diagram
Thanks for the responses.....can someone point me to a diagram or manual for the fuel system on a 1641?
